| User | Kudos |
| 13 | |
| 10 | |
| 7 | |
| 5 | |
| 5 |
What do you think if there is an BD SubVI (right click) option in enforcing SubVI code version to be absolute. Maybe through verifying SubVI's hashes etc, when individually enabled; to protect the source distribution from tampering. By default, LV will look for missing VIs if not found in its original path. That opens a window for the user to load another VI in place of the intended VI as long as it doesn't break the arrow and with a warning. An option to enforce SubVI identity in a password protected main/sub VI can be useful in maintaining the integrity of the codes.
