8 | |
6 | |
4 | |
3 | |
2 |
Currently the build specification name, the output filename and output path of the build is hard coded on the "information" page of the Build specification properties window.
It would be a HUGE help if optionally the version number from the "version information" page could be added to the build spec name / filename / path. Right now unless I continously change the filename and folder path the project explorer overwrites the existing build and just by looking to the file name I dont know which build is this exactly.
Functionality available in LabVIEW 2013 and later. See the Application Builder Enhancements > Creating Directory Versions in Build Specifications section of the LabVIEW 2013 upgrade notes here: http://www.ni.com/pdf/manuals/371780j.pdf
