Currently if you draw a diagram disable structure around a section of code any wire coming out of it will be set to "Use Default if Unwired". This is almost never the desired behavior, and can easily lead to bugs if people forget to connect wires through on the Enabled case. The VI should be broken until the developer makes any necessary changes in the Enabled case.
Option for Disabled Structures to Not Use Default Value for Unwired Output Tunnels - NI Community
