When I change Y-Axes propertys the layout of two or more axis crashes in that way that the distance between graph and the axis is not in the right way or two axis are at the same position. In that case I have to end my application and reset the layout by right clicking context menu and do the advanced function "Reset scale layout".
The idea is, doing this programmatically inside my application. Currently I do not have a chance to do it.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
