| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
The actual system Localize LabVIEW using export to txt, then modifying to new languages for importing them again is good for easy and finished programs that need not to be edited top build new versions, because every time I have to make modifications, I have to reedit txt very carefully looking where to write new language.
I think the better is to write label for different languages every time I create a new variable.
If a label is copied and the new name is similar, then I have to modify only a part of the label in every language.
