5 | |
3 | |
3 | |
2 | |
1 |
Properties of a numeric control or indicator is using a scroll box to set the Type (see dump below). A closer look reveals that this dialog is poorly laid out - there is plenty of room to display all the contained information without having to resort to a scoll box. This issue appears to be specific to LV2012. In LV2011sp1 it is nicely done.
This is a very simple and low risk thing to correct and improves usability at virtually no cost. It may appear as an insignificant thing, but a top notch tool like LabVIEW should take care of all such small details.
Here is a dump of before and after the improvements...
Implemented in LabVIEW 2014
