Currently, you cannot search and find examples by name in the example finder, only by specific keywords which may or may not be in the name. Including both the file name and the non-abbreviated terms of its name would be much easier. It would both help people find the files, and make them easier to interpret the names, which are somewhat confusing at times.
For instance, if you wanted to find "Acq&Graph Voltage-int clk.vi" example which you couldnt search "acquire graph" or "Acq&graph" and find it which is unintuitive and confusing. It also makes it difficult to direct other users to.
Kyle Mozdzyn
Applications Engineering
