3 | |
3 | |
2 | |
2 | |
2 |
A change of inputs or outputs in a SubVI leads to the need for manually Relink all the calls to the SubVI.
As I often use the SubVI at many different places I would appreciate a function that automatic relink all the instances. Something like this:
