5 | |
4 | |
3 | |
3 | |
3 |
The Control-E shortcut to toggle between Items and Files view in the Project Explorer should go away. I often have my LabVIEW Project window sitting off to the side and don't realize it has focus. I hit control-e to get to the block diagram of the front panel that's sitting in the middle of the screen, not realizing it that it's not the active window. This wouldn't be a big deal - I'd figure out quickly that the wrong window has focus - except LabVIEW stalls for 30+ seconds trying to display the Files view during which time I can't do anything.
