2 | |
2 | |
2 | |
2 | |
1 |
If you edit a loop you can click to a tunnel and replace it by a shift register and reverse. But why is nothing like this for stacked sequences and the local sequence variables?
Here some pictures to illustrate what I'm thinking about:
Replace Tunnel by Shift Register
change tunnel to a Sequence Variable
Replace Shift Register by a tunnel
Change Sequence Variable to a tunnel
Remarks: I'm using LabView 2011SP1 German
