| User | Kudos |
| 9 | |
| 9 | |
| 4 | |
| 4 | |
| 3 |
I would like to see an option or VI that save / load the state of a VI and there SubVI's at a certain time (all controls I guess).
Background:
In the development of measurement software it is important, in terms of reproducibility of measurement results, to implement an option that save all scalable objects at a certain time (device settings also program settings) which depending a measurement.
Save program settings:
I know there is a way to do this by calling the VI reference and get the control values with property node and save them. But I don't think that's an accurate way because you have to manually do this with every SubVI's reference if you won’t to save them too.
Btw: in LabVIEW NXG, which I really like, it seems no way to do this because there is no 'Get Control' property node?!
Suggestion:
- two VI's which save/load all scalable program settings to/from file (hopefully in the standard data save VI Palette)
