| User | Kudos |
| 13 | |
| 11 | |
| 9 | |
| 7 | |
| 6 |
It would be cool to have the Search 1D Array Function be capable of accepting an array at the element (to search for) input. The output would be an array of indices corresponding to each array element. Of course I can just put a Search 1D Array Function in a For-Next Loop, but he Search For Elements mode should provide a performance gain since this would be one native function call instead of 1 for each array item called inside the For-Next loop, right? : )
I am using LabVIEW 2014 Home And Student version, so sorry if this already exists in newer versions.
