| User | Kudos |
| 13 | |
| 11 | |
| 6 | |
| 6 | |
| 5 |
Quick Drop (Ctrl+Space) is often used to work with a selected VI (e.g. Ctrl+P replacement). The Quick Drop dialog window opens with blank text box. Default that text box to the VI name if one is selected when Quick Drop is opened. That text should be pre-selected so that typing replaces it (no extra keystrokes for backward compatibility). Furthermore, it would be extra nice if the selected VI was automatically highlighted in the list.
