| User | Kudos |
| 13 | |
| 10 | |
| 6 | |
| 6 | |
| 5 |
When using the Sahred variable (SV) with "Bind to source", the SV uses the datatype of its source.
If you are using the datatype "double" you can see all fractional digits.
That doesn't make sense all the time - e.g. if you want to display temperature values.
Our idea is to give the user the opportunity of controlling the number of digit of precision.
