11 | |
10 | |
3 | |
3 | |
2 |
Tabbing will work for clusters on the front panel, currently we are using "Ctl+Down arrow key" to focus control in the cluster "Ctl+Up Arrow Key" to come out from the cluster
For use Tabbing feature for clusters, I need to use "Ctl+Down arrow key"/"Ctl+Up Arrow Key".
While tabbing on the front panel is there any way LabVIEW automatically detects the Clusters and it will directly focus the first element of the cluster and when you click Tab on last element in the cluster it will come out and focus the next availble control outside the Cluster (if next control is again Cluster it will focus the first element of the next cluster)
