6 | |
6 | |
3 | |
2 | |
2 |
The provided model templates (fitting, optimization, etc. listed here) have the ancient icon style where the text is actually merged into the single layer of the icon.
Since in the typical scenario the text will be immediately changed to reflect the actual customized model name, it would be reasonable if these icons would have the current text editable in the icon editor instead. Currently, we need to erase the icon background before we can start typing or we get a mess.
For example, in the nonlinear fit model, the text "curve|fit|model" should be in the text tab, and not contained in the icon background (see image).
Suggestion: the model template icons should be blank and the current text should be pre-filled, but editable on the text tab of the icon editor.
