| User | Kudos |
| 13 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
It'd be great if when sorting a column of items (say in the Multiple Variable Editor, or a table of data), the values were sorted using a numeric sort rather than a literal sort (ie. DI10 should not come after DI1, and DI20 should not come after DI2).
There could also be a specialised string sort function which takes in a string array and provides an option for a numeric or literal sort.
