11 | |
8 | |
3 | |
3 | |
2 |
The current version of the Ethernet/IP tool kit 781656-35 only functions as an adapter. I need it to also function as a scanner. Specifically to take control of the point I/O module 1734-AENT module of the Allen Bradley RSlogix 5000 PLC. I need the Labview to replace the PLC RS l5000 logix software. I still want to use the Point IO modules.
