6 | |
5 | |
2 | |
2 | |
2 |
Right-Click to a single file in the LabView project folder (LV 2011SP1) opens the windows file property dialog.
Trying the same with several selected files or a folder (file view) does not work because the property entry is not there. Please also add it for multi-selections.
Alternatively (for my purposes) it would be sufficient to have the possibility to add or remove the read-only flag for all selected files or folders (and sub folders).
