Community Browser
Post an idea
Searched briefly but couldn't find any ideas about this.
I know we have the ability #via_ignore comments to ignore specific tests for a specific VI, but I am looking at a different use case.
Here's the use case, I use DQMH. When you create a new DQMH module there is a lot of plumbing code that comes with it. It's standard stuff. Very rarely do I have to open or edit it. Much of it is scripting generated. It often fails tests but I don't care. In addition to failing, it takes up test time, which slows my feedback loop. I would a way to signal to VI analyzer to skip these files. I know I can use the VIAN API to limit the files it checks, but I was thinking there had to be a better way.
Implementation Ideas - I had 2 main ideas
- Regex matching on VI names - with the regex pulled out of a text file somewhere ala gitignore. Many of the DQMH generated VIs have standard names, so that is easy. When generating events, they don't but you could easily add a prefix/suffix or something that the regex would pick up.
- Using the Tag API to tag the VI. I like this because the scripting can just apply the tag or apply it to the template the scripter uses. Downside is: kind of hidden from the user and perhaps if I decide to make some edits to this VI  I may want VIAN to stop ignoring it and it's not immediately obvious how to do that.
Note:
I picked the Execution and Performance Label because it didn't seem to fit any of the labels easily. If this is the wrong label and you are an admin, please relabel it.
I find it rather depressing how so many of the new user questions contain code that is just a big Stacked or Flat Sequence structure.
I understand that we need to leave the Sequence Structure there for compatibility with old (poorly written) programs and the very few places we still have to use it...
But it's beyond time to deprecate it.
Warn users with a pop-up or the big red X like the old "Write To Spreadsheet vi" or something that this is an old outdated programming structure that should not be used in new programs!
It would be really helpful if we could specify a unique "friend" or group of "friends" for each method in a class, rather than a setting that applies to all members of that class.
I have long defended NI's decision to bind the lifespan of DVRs to their creator VI but, with the addition of malleability (totally awesome) and the fix in LV 2020 that allows "New Data Value Reference" to be called directly in an inlined VI (thanks, AQ), the ephemeral auto-cleanup behavior of DVRs is now a big blocker to a reference-based strictly-typed API.
I want to open a strictly-typed and malleable reference and keep that reference open until I choose to close it, regardless of whether the opener leaves memory. Without malleability, I could delegate the DVR creation to another thread/VI and get the persistent reference back by callback but I can't have the home-baked persistence and the malleabilty.
Please add a persistence/auto-cleanup flag to New Data Value Reference so I that reference can persist if I want it to. (I need both the persistence and the malleability to write some really cool code.)
Here's an old request for this feature that was declined, but things have changed a lot since then: https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Persistent-DVR-s/idc-p/2856348#M27799
Provide a way to save and recall sets of probes for a running application.  A developer could then provide sets of various probes that would help the end user.  The superprobe would remember the VI paths and locations in the block diagrams of the application's SubVIs and automatically load VIs from disk or monitor existing re-entrant copies in memory.  The superprobe would have a front panel layout, like a global VI, to look like a custom dashboard of important data values in the applicaton.
String functions accept array input.
Example:
Benefits:
  1. Avoid placing For loop or Subvi with for loop
  2. Looping performance can be improved with better logic inside the function.
  3. Block diagram space saving without for loops
Thank you
Adarsh
CLA from 2014
It would be really nice if we could build PPL for multiple targets. The LV help states:
"If a VI calls a packed project library compiled for one target and you open the VI on another target that has a different operating system, the packed project library fails to load."
We should be able to choose which target's compiled code shall the builder include in the PPL. This would make the use of PPLs in a multi-target system so much better.
When writing a string key to a configuration file with the Config file "Write Key.vi" on the File I/O palette, the value will always have quotes around it because of the "Add Quotes.vi" in that particular method as you can see in this image.
Not all external programs handle ini files with quotes around strings as well, and this question was already asked and answered in 2010, but for some reason NI never added this VI or the option to remove the quotes to the actual palette.
I would like to have the option to have my string keys with and without quotes.
The built in web services are a handy way to expose a simple RESTful API to a LabVIEW executable. And it's nice that it supports hosting static content like HTML pages and javascript. But it would be extra nice if we could host directories with dynamic content, such as a folder of log files that we want to expose for troubleshooting purposes.
For example, if I have services that generate debug logs, I could do something like start up a python simple http server to host the log directory and make the files accessible remotely. As log entries are appended, or new files are created, they are automatically made available via browsers (or programmatic GET operations). It would be really cool if the native labview web services could do this, to avoid having to set up a separate process (and manage another port number). If I've already set up a web service for remotely interacting with this process, it feels natural that I would be able to extend it to host stuff like this.
Since LabVIEW 2017, it's possible to build application with a compatibility with future version of run time engine.
This option is set by default but can be disabled.
I just discover that this option is set for real time applicaiton and cannot be unset. I mean that if you build your application in with labview real time 2017, it will run with a system installed with a newer version of LabVIEW Real time.
This can be a good idea, but I'm a little bit surprise that I cannot have informations on that options for real time application and I can't control it.
Here is a way to test it. Tested on a real time desktop with pharlaps.
Install RT target with LV 2017.
Build an application and set it to run as startup. A simple application writting something in the console is enough.
Make sure your applicaiton is running at startup.
Update your system by only installing LabVIEW real time 2019.
Restart your system and your application is still running !
Because I faced an issue where LabVIEW 2020 broke my application build in LabVIEW 2017, I'm asking myself how NI can garanty that a real time system will work in any case if we upgrade the system to a higher version of LabVIEW real time version without recompiling the application.
Real time system can be used to control system that can be a secure system. If a user update by error a system, I want to keep my system safe for user.
So my idea is to remove this option or give access to the user to unselect this option to avoid any bad behavior.
best regards
We use Queued Message Stage Machines a lot and often send messages through API calls. In a state machine I prefer using enums to determine the state and in the QMSM that would be useful too because sometimes a typo in a message in an API call stops it from working.
However, the Message Queue functions accept string only.
Even if we make changes to the message cluster or make the VI polymorphic but we would then need to do it every time we are setting up a new machine with LabVIEW. Would this be useful for anybody else?
Please implicitly consider array index during index / replace elements in In Place Elements Structure if I am starting from Index 0
Present method:
Expected method:
[admin edit 2021-02-24]: placed images in-line with text and removed them as attachments
Report Writer BEFORE WIndows 10 was SUPER ROBUST! Now that Windows 10 came along there exist many "turds" left in the Registry when folks UPGRADE from Office 7 to Office 10.
What happens is the Registry NEVER NEEDED to be kept clean of extra junk because NOBODY EVER UPDATED Office.
Now every Joe on the planet updates their Windows 10 with the latest Office 10..
What happens if they do NOT FIRST UNINSTALL, is the Registry is left with "turds"
When Report Writer uses ActiveX to make calls to use Word, in the old days, there was a SINGLE key in the registry to allow the calling program to gracefully start Word or Excel, or whatever.
NOW< with Windows 10 there are FREQUENTLY multiple "keys" in a Registry that causxe the LabVIEW Report Writer to "Gag" and "Hang up" doing nothing.
The SOLUTION is for the Report Writer to PARSE the Registry for valid keys and allow the request to be passed to the propper called process.
If this is not clear, please look up the SR below. There are a TON of examples and videos explaining how to fix it.
I have been working with LV since Dr. G was roaming the halls on LV 3...
This is the FIRST TIME Report Writer has gotten "sick".
This is an EASY FIX for the devs and since Report Writer is a purchased plugin they sould be able to update it so it works well.
Currently, they have us fiddling with the Registry or telling customers to uninstall and reinstall Office. That is a BIG FAT NO-NO to big companies because Office WORKS COMPLETELY for them and even programs like SolidWorks and DXP that use Word and Excel for stuff.
My number 831-455-0418
DEVS:
Please see: Request #: 00994109] Can not get EXE BUilder to run on WIn 10
The idea:
Make 'Get LabVIEW Class Parent And Member VI Information.vi' work on the type of data on the wire and not only the type of the wire to make it possible to use it together with 'Get LV Class Default Value.vi' so info on classes from source distributions and PPLs can be extracted.
This would make such classes easily available for use in dynamic factory pattern designs.
The reason:
The current implementation of 'Get LabVIEW Class Parent And Member VI Information.vi' cannot give me any info I don't already have access to in development. The only classes it will work on are the ones already loaded/known as it returns result based on the type of wire instead of the type of the class data on the wire. This limitation (as I see it) greatly decreases the use of the VI.
The same can be said for the 'Get LabVIEW Class Information.vi' as can be seen here:
As can be seen the wire needs to, at some point, be present and wired into a 'To Variant' for the VIs to return correct results. This will sadly never be the case for any dynamically loaded class from a PPL or a source distribution!
I use classes widely for extending functionality and often I want to have a dropdown or a list or a tree of classes of a specific hierarchy or interface maybe even filtering the ones that implement a certain dynamic dispatch vi. I have been using config files created from the development environment for this, as a workaround, but in 2020 I wanted to get a live integration of new classes by scanning for new classes, loading them and registering their data. (In practice what I'm doing today is that I copy a PPL containing classes into a common PPL folder and register the classes and their heirarchy/members in a config file. This makes the new classes available to the application without a need for rebuilding it.)
An example could be a UI element that allows the user to launch an actor from a ring control. So what types of actors are available? The application cannot know this. Any actor that comes from a PPL or a source distribution will be unknown so the application cannot properly populate the ring control. It is possible to find all classes by looking at the extension, but not what hierarchy they belong to. In 2020 this could have been done using the following code (if it worked as I suggest):
Sadly this will never return anything useful as it can only look at the LabVIEW Object wire.
I guess all the other data type VIs work in the same way, however that has never been an issue as the data types could only be mixed when they were variants already and there isn't (to my knowledge) a load data type by name/enum VI.
In my dream scenario I wouldn't even have to load the class into memory to acquire the info. A path based version of 'Get LabVIEW Class Parent And Member VI Information.vi' would be perfect for use with dynamic factory patterns. This is however a minor issue as the data can be stored between executions instead, but one can dream right :).
Sorry that my ideas/requests always end up being walls of text...
Idea
The idea is to implement an option to choose for which RunTime-Version you want to compile your executable.
With this you could always use the newest LabVIEW development version but do not need to update all systems with a RunTime-Version.
Background
When changing from LabVIEW 2019 to LabVIEW 2020, you need to update every RunTime-System also to version 2020.
This is difficult, if you have many worldwide runtime systems with different projects, where you can not easily update a RunTime-Version because of technical restrictions in production or access to the system.
This results in parallel use of different LabVIEW development versions for all of your projects.
Means a mess because once open a project in the wrong/newer LV-Version you have to store all changes "for older LV-Version" to continue work in right version.
Or, to avoid this, not upgrading to a newer LabVIEW development version and still working for example with LV16 in all projects.
Conclusion
Best way would be if you can update all projects to LV20 development system, but still be able to directly built executables for older runtimes.
The code below will execute without error or warning. The value returned will be 127 in this case.
Why is that? I understand the error 91 is returned if the typedefs are incompatible but if the type is different but compatible I would expect a warning maybe?
Cheers,
Jimmy
Being able to initialize arrays as empty sets would be handy - not just as 0 or NaN.
This idea was posted years ago and declined for lack of interest  (it got 6 out of 7 necessary, but I would have been the 7th!).  I would like to bring it back, I would like my application to have access to it's own version number.  In fact you can open the project programatically and see some build properties but not that one.  I can then grab the version from the build properties and set the default values on my FPGA code before compiling.
I was trying to make a pre-build VI that would look at the build properties and copy the version data into a control.  Can't be done.  I find this very useful to make sure that my RT system and my FPGA code have the correct versions.
Same as with an about box, or version checking for compatibility.
The previous thread suggested a routine in the FileVersion.llb but that seems to only be available in a single platform.  Not useful for RT linux or Mac.  The version is not available until the executable is built which does not work for FPGA.
At the moment my only recourse is to hand copy the version from the build properties and then set those as a series of 4 integers on the FP.  (Then select them all and set their values to default, hence the other suggestion about right click)
Consolidate all LabVIEW G files into two file extensions:
  • Source LabVIEW File (*.xx) - Human readable source code files (e.g. *.vi)
  • Compiled LabVIEW File (*.xxc) - Compressed compiled binary files (e.g. *.vic)
Justification:
LabVIEW is proprietary. I need LabVIEW to open LabVIEW files. There are +15 LabVIEW file extensions to create LabVIEW G code. Recognizable LabVIEW extensions are worthless because I still need LabVIEW to open and edit the files. Some LabVIEW files contain compiled code, whereas other LabVIEW files are glorified name-spacers; some are UI components, while others embed compiled LabVIEW code into other LabVIEW files.
With every new LabVIEW version, capabilities are added that inherently cause inconsistencies between LabVIEW file types, environments and overall behavior. Let me explain.
Problem:
  1. Current LabVIEW file types don't adhere to consistent behavior:
    • Libraries (lvlib, lvclass, xnode, xctl) are xml files (human readable) but also contain encoded compressed data (non-human readable)
    • VIs (vi, vit, vim, ctl, ctt) are binary files that can contain compiled code (or not)
    • Libraries (lvclass) add dynamic capabilities like dynamically dispatched VIs and can embed class private data controls (or not for interfaces) using the same extension, rendering the extension useless
  2. Inconsistent code redistribution
    • Distribution libraries (llb, lvlibp) embed compiled code differently
    • Packed libraries (lvlibp) resolve system paths differently that source
    • Libraries (lvlib, lvclass) lack the capabilities to embed reusable libraries for redistribution - Similar to Python's PIP library
    • Some 3rd party applications (like VIPM) to manage distribution inconsistencies add more file types and compounds the redistribution problem
  3. Compatibility discrepancies
    • VI (Poly, Express), Class (Class, Interface) already introduces development idiosyncrasies that could be resolved with a one "file" fits all methodology.
    • More file extensions equals more variability, increased maintenance time, and puts ownership on developer community to find discrepancies
Proposed Solution:
  1. Consolidate current LabVIEW G source files (vi, vit, vim, ctl, ctt, lvclass, lvlib, xnode, xctl) into a single Source LabVIEW File (*.xx) that is human readable (i.e. xml) that contains no encoded, compiled or compressed data. - Similar to NXG's xml format
  2. Introduce Source LabVIEW File (*.xx) nesting/namespacing to remove the need for external Library files (lvclass, lvlib, xnode, xctl) - Similar to how C# or Python files allow for multiple methods within a single file.
  3. Add a build spec component to generate a Compiled LabVIEW File (*.xxc) that embeds the Source LabVIEW Files and Compiled Object Cache - Similar to Python wheels/pip package manager
  4. Allow developers to use the Source LabVIEW File (*.xx) or Compiled LabVIEW File (*.xxc) interchangeably in their development projects - Similar to how Python's *.py or *.pyc can be called
Features:
A single LabVIEW Source File (*.xx)...
  • can be human readable (i.e. xml) - Editor agnostic
  • can embed one or more LabVIEW Source Files - Single file libraries
  • replaces *.vi, *.vit, *.vim, *.ctl, *.ctt, *.lvlib, *.lvclass, *.xnode, *.xctl
  • adheres to common coding language extensions (C#=cs, Python=py, Java=java)
A single LabVIEW Compiled Files (*.xxc)...
  • is a specific build specification for packaging and distribution
  • contains the source files (optional) and compiled object cache
  • can embed run-time components - Package distribution
  • adheres to common coding practices (Python=.pyc, Java=.jar)
  • replaces *.lvlibp, *.llb, [*.exe]
LabVIEW currently has +15 extensions to develop G code:
(Not including, LV Projects, NXG, VeriStand, TestStand, LabWindows/CVI, etc.):
- Virtual Instrument (*.vi)
- Virtual Instrument Template (*.vit)
- Malleable Virtual Instrument (*.vim)
- Control (*.ctl)
- Control Template (*.ctt)
- Virtual Instrument Library (*.llb)
- Library (*.lvlib)
- Class (*.lvclass)
- XNode (*.xnode)
- XControl (*.xctl)
- Packed Library (*.lvlibp)
- Palette Menu (*.mnu)
- Run-Time Menu (*.rtm)
- Data (*.tdm, *.tdms, *.lvm, *.bin3, *.rc)
Should we consolidate?
Since LabVIEW 2017, the default build specification check the option "Allow future versions of the LabVIEW Runtime to run this application".
I don't undertstand why it is checked by default when you read the help that said "Disabling this option prevents any changes to the performance profiles and helps you avoid unexpected problems resulting from compiler upgrades."
Because NI and me doesn't know the future, NI will never garanty that your application will run with all the future LV Runtime. I know it well because I'm facing this issue with le LV RT 2020 that breaks the execution of different application that I have buid in 2017 SP1.
The behavior is a little strange too, because, even if you have the run-time use to build the application on your computer, the application will use the highest one present one the computer.
This options can be very usefull, and I appreciate it, but maybe we need to have more control on it. So my idea is to give to the user the ability to list supported or unsupported LabVIEW Runtime.
This will help us managing future LV Runtime without having to recompile the application which seems to be the goal of this option.
for Example :
[MyApplication]
ExcludeLVRTe = "2020,2021"
Regards
