Community Browser
Post an idea
For the most part coersions can be broken down into two classes: lossy (e.g. 64L to I8) and safe (e.g. U8 to U16). Why is there only one color option for coersion dots?  Could the vi analizer have seperate settings for max allowable safe and unsafe  coersions?
Support project based vi-analyzer configuration which containing target specific information (important e.g. to correctly analyze FPGA VIs) to be executed with the vi-analyzer api to be integrated into CI process.
Direct to PDF reporting is an extremely important feature to provide customers.  It cannot be relied upon that the customer has MS Word or the like installed.
There are a couple of LV PDF toolkits supplied by developers.  However, the problems with these include that they are (a) not updated or well-supported (b) buggy (c) have out-dated dependencies such as .Net 2.0 (d) restrictive licencing for deployment.
Good reporting tools are essential and NI should develop and support a direct to PDF toolkit.
Hello,                    (sorry for my english, i will try to do my best)
I think the management of Breakpoints and  Probes is not logical and not enough powerful.
I propose a new approach.
LabVIEV would need a real debugging environment, much more powerful, like this :
1st  :  Probe management is not logical
           Why ?  A probe is only to watch a value on a wire (not to stop the code)
2nd : To stop the code, the Breakpoint, with ou without condition(s) ... (conditional or unconditional Breakpoint)
3rd  : Conditional Breakpoint:
  •   A conditional Breakpoint stops the code on a wire, according condition(s) on this wire itself;
       or / and  according condition()s on other wires. (very powerful feature)
  •  The breakpoint condition use binary operators (C language), like a Formula Node
  •  To Use a Numeric value or a boolean value into a Condition, you must first place a Probe
      (Normal, before using a value, we must first take it.)
  •   The Conditional Breakpoints are only available with Numeric and Boolean values.
      (As the current version of LV)
The breakpoint Manager highlights the Breakpoint on which the right click has been made.
Inside the Breakpoint Manager, we can see the corresponding Breakpoint via "Find on Diagram".
Outside of comparisons, Triangles are becoming an endangered species on my Block Diagrams.  The Compound Arithmetic Node is a very handy tool, and armed with my (function preserving) RCF plugin/QD shortcut they are replacing all math triangles.  I use them a lot, and so should you.
One final hurdle to reaching total happiness: the process of inverting inputs and outputs is a bit awkward at best.  Right-Click, scroll down, find Invert (right in the center of the menu of course) and try not to have the muscle spasm that results in 'Remove Input'.  I would really like some type of shortcut (double-click, shift-click, ctrl-click, anything) to quickly toggle the inversion of a terminal.
(I would also like to enlarge those Inversion circles while we are at it...)
(Ironic that the LV logo is a combination of the Add primitive and the Sequence Structure....)
In .NET each of the integer data types provides two constant fields, named MinValue and MaxValue. These constants return the minimum and maximum values that can be stored in that data type. For example, for Int32 MinValue would return -2147483648 and MaxValue would return 2147483647.
It would be nice if there would be similar constants in LabVIEW for all eight integer data types. These constants would be similar to the DBL constants that already exist: +Inf, -Inf, Machine Epsilon and NaN, and would be similar in concept to string constants such as Space Constant and End Of Line Constant.
The new constants could be placed in the Numeric palette, or in a new sub palette of the Numeric palette, as shown in the image below. I would be happy with any location.
I am aware that I can easily create constant VIs to implement this functionality, which would be very similar to how Space Constant.vi is implemented, but it would be nice if the constants were built-in.
My current workaround when I need the min or max values of an integer data type is to drop a numeric constant and type something like -9999999999999999 or 9999999999999999, which after Enter is pressed LabVIEW correctly coerces to the min or max value.
There is no way to get to the GObject property of "Position" in the dialog box. Its only available via property nodes, but if you want to statically set the control position, this is a pain.
I run into this when I have multiple, similar VIs that i insert and remove into a subpanel. in order to set the controls to be in the same position across the VIs, i have to use the property node for a 1 time use.
Many languages have that, why not LabVIEW?
See here for implementation details.
This would help me out loads to solve Project Euler's problem faster, at this moment LabVIEW is ranked 53, it would be nice if we had tools that help us improve that.
It will be good to have a option like "Close all but this" in File Menu; which will be very useful to close all the sub Vis after debugging and just run the main Vi with all sub vis closed. i feel it would be very good to have this feature.
This is similar to the one in Notepad++.
It seems like it shouldn't be too much to ask for a proper Smith chart (with markers and everything!).  Seems like it's already hiding somewhere...
These function names create undue confusion. Every semester, new students to LabVIEW post questions on the NI and LAVA forums asking how to use these functions to open, edit or load data from an Excel file (.xls).
Unfortunately, the name spreadsheet file has become synonymous with Excel. Even experienced computer users have an expectation of some sort of intelligent file when reading the title "Read from Spreadsheet File".
These functions should really be renamed to 'Read from' and 'Write to' DSV file...
Delimiter Separator Values  (wikipedia link)
NXG needs an Idea Exchange.  The feedback button is a lame excuse for a replacement.  Why?
  • I can't tell if my idea has been suggested before.  (And maybe someone else's suggestion is BETTER and I want to sign onto it, instead.)
  • NI has to slog through bunches of similar feedback submissions to determine whether or not they are the same thing.
  • Many ideas start out as unfocused concepts that are honed razor sharp by the community.
  • This is an open loop feedback system.
Let's make an Idea Exchange for NXG!
I use the following shortcuts in Quick Drop:
"+" - shortcut for "add"
"-" - shortcut for "subtract"
"*" - shortcut for "multiply"
"/" - shortcut for "divide"
And that got me thinking that what I would really like is to be able to type simple math equations and have Quick Drop generate said equations.
So if we typed "(*3+2)/(4+5.68)", Quick Drop would spit out the following:
-Carl Wecker
There needs to be a LabVIEW API for Requirements Gateway.  API functions would be
1. Open/Create Requirements Gateway Project
2. Add/Remove Requirement Document
3. Add/Remove LabVIEW VI
4. Get Code coverage
5. Create Report
etc
I think this would be extremely useful with trying to dynamically get code coverage, and really extend functionality
The idea is to enable read access to the "Error List" programmatically (scripting) in LabVIEW.
I had the need in the past to draw isosurfaces from 3D volume data. My workaround was to export the data in xplor format (see also), then display the isosurfaces using molecular graphics software (such as UCSF Chimera). This is too indirect.
The code to do this directly in LabVIEW exists already in the NI Biomedical Startup Kit 3.0. Look under the section "source code":
  • Create isosurface from 3D volume data
  • Draw isosurface for 3D picture control
While the full biomedical startup kit requires quite a few extra toolkits to work, these two isosorface tools can work in plain LabVIEW.
My suggestion is to add these two tools (and maybe others?) to the standard 3D picture control palette of LabVIEW.
They are of general interest. 😄
There are many array functions that don't need to depend on the dimensionality of the array - for example most of those in the "Probability & Statistics" menu (Mean, Median, Std Deviation etc) and some in the Signal Operation (like Scale, Normalize).  But if I want to use one on a 3D array, I must first make a copy by reshaping to a 1D array, which can be very memory-expensive.  I'd like a node on the "In Place Element Structure" which accepts an array of any dimension, and makes the data available as a 1D array of that type.
I've suggested a similar idea before here, but perhaps I made it too complicated to receive any comments!  I keep running into this problem, so lets try again.  Smiley Happy
I'd love to see a handful of built-in false-color colortable choices for the Intensity Plots.
I know there's programmatic control over these things - I wrote my own 4-5 years ago. But the black-blue-white should be one of several common selectable colorschemes.
I labeled my own as:
 Greyscale B->W
 Greyscale W->B
 X-Ray
 Yellow Hot
 Rainbow
 Rainbow #2
 Fluorescent (green)
 Blue Red Green
 Planet Earth
Perhaps one of the front panel (and Property node please) off of the Z-Axis submenu, listed by title.
I also have the ability to invert top/bottom or choose the color-inverse (photographic negative) for even more colors.
Attached is a sample of some common colortables I routinely use.
2nd attachment is a snap of the VI I use to create the colors based on colortable constants.
3rd attachment is my messy but functional code (Block Diag of attachment 2)
FIR Filter is almost the same as convolution, except that it has a init/cont terminal while convolution has an input for algorithm (Direct, frequency domain). FIR filter always uses direct convolution.
If "cont" is not used, convolution based FIR filtering could be orders of magnitude faster because it scales much less steeply with input sizes. Examples have been discussed where switching algorithms from "Direct" to "frequency domain" can turn minutes into seconds (e.g. 1M points and 5k filter).
While the knowledgeable programmer can of course make his own using the convolution primitives (also programming around other limitations because this idea is not implemented :(), it might be more intuitive if the FIR Filter had an "algorithm" input where we can select between the same choices as for convolution. (From my casual understanding, "frequency domain" would ignore the "cont" input because it is incompatible. This can just be mentioned in the help.)
I would like to encourage NI developers to produce an Advanced Signal Processing Toolkit (with the wavelets functionality like the one for WINDOWS) for MAC OSX.  I have been using Labview for some time now but i really dislike having to change OS platforms just when i use wavelets.  I am sure I am not alone here as there are many using Labview in the OSX environment.
