Community Browser
Post an idea
It would be nice to have an option in XYgraph that could allow the user to define some set of spatially related points (or cluster in statistics) by drawing some boundaries with complex shapes using the mouse. Here is the problem that brought me to write this post. Let's say that we have a series of data {x1,x2...xi...xn} that represents the duration of time between two adjacent heart beats. The pointcare plot is the representation of the points [xi,x(i+1)] and that can be achieved to by the XYGraph function. Using this graphic, it is expected that adjacent intervals with almost similar values will form a cloud (circular, eliptic or with more complex shapes) centered around the average values of the xi. Now, unusual changes between adjacent xi values in the time series (lower or higher x(i+1)) will result in points outside of the primary cloud. This is an easy way to identify abrupt changes in a time series.
The step I'm blocked with the following. After I used the XY graph to plot the [Xi,X(i+1)], I would like to use the mouse the draw the border of the primary cloud and extract separately the indexes of the point in or points outside the border.
Again, I really appreciate your help for that.
Olivier
Allow boolean for indexing.
This way a quick array selection can be made without the need for building loops.
(for those familiar to matlab: matlab indexes like this)
Add support for array calculations in Formula Node.
Seems not that much of an effort, since LabVIEW is very array based.
Now only scalars can be dealt with.
(Mathscript is an add-on that can do this, however I would like to see this as base functionality).
The PID Autotune would be much more useful if it were refactored so it could run on RT targets.  I would suggest replacing the embedded calls to viserver to open up wizard panels
with a MVC architecture that would allow a better separation of the core PID logic and the HMI components.
I'd like to have a PDF export function within the Report Generation Toolkit.
So that no additionl software have to be installed on the target system to generate PDF files including graphics an text.
The PDF format is the most used format for sharing documents because nearly everybody has a reader installed.
It looks identical on every computer and is perfectly to print.
Software like OpenOffice, Word or programming languages like PHP supports the generation of PDF files, why not LabVIEW?
Regards
I would like to see more native support for compression and encryption/hash algorithms.
When it comes to compression and encryption. We are very much the poor relations to other languages that have a plethora of source and examples for SHA1, DES, 3DES, Blowfish, HMAC, Ryjindel, AES (encryption) and LZO, LZMA, LZW, GZip, JPEG2000 (compression) to name but a few.
Apart from "Zip" (which can only be used on files) and "twofish" (which is hardly an industry standard because of security concerns) we have very little choice but to use DLLs and SOs meaning our applications violate one of the biggest reasons for using LabView........cross-platform. We have very little in our tool-kit to make efficient and secure network applications for example. Especially if we are required to interface to existing systems that ave used these technologies for many years.
We cannot even write applications to access Twitter any more!
With the introduction of "Stream" prototypes in the new LV2010, it is essential to have these tools in our palettes.
Charts and graphs in LabView have been driving me nuts for years. What I would like to see is a simple chart (maybe even an "Express Chart") that has a single dimensional array input and a timestamp input. Values in the array would automatically be plotted on their own plot and the time stamp would be put in the X-axis starting from the left. An option to just use the current time if no timestamp was input and amount of data displayed on the X-axis can be adjusted on the fly by setting the X-axis TIME/DIV
While the intrinsic Math functions all support EXT, DBL and SGL, few of the remaining Math (or Signal Processing etc) functions support anything except DBL.  For many cases, using SGLs is sufficiently accurate, while using less memory and often being faster to compute.  While some functions are implemented solely in G (and therefore it is easy to create an SGL copy, though not so easy to integrate in a "polymorphic" way into the existing menus), most functions call a DLL routine.
I suggest that SGL (and CSG where appropriate) be supported for all Mathematics functions, including Signal Processing, and the Advanced Signal Processing Toolkit.  Is there anyone else who would make use of these if available?
Note: two "addons" have been released by NI which begin to address this.
Single-Precision Basic Linear Algebra Subroutines (BLAS)
Currently I'm busy with GOOP and I came across the following problem.
I have a validator class. The purpose of this class is to validate data. The validator class as a number of childrens...
Validate IP address
Validate string length
Validate inRange number
Validate Alpha
The main, validator, class has a function called "valid?" This function has 3 inputs and 3 outputs
Inputs:
- Object
- The data that must be validated
- Error
Output:
- Object
- Valid?
- Error
The children classes must inherit this function and overwrite it. Now the problem is is that each of the above validators have a different datatype which must be validated....
Validate IP address has a string as input
Validate string length has a string as input
Validate inRange number has a number as input
Validate Alpha has a string as input
Now you might see the problem. To get the children to inherit the function from the main, validator, class the connector pane must be the same as of the datatypes... This means that I have to choose in my main function to use a string or a number as input... This is something that I don't want... I want to be able to select a datatype called "yet unknown datatype" in my main "valid?" function in the main, validator, class. So that I can use any datatype input in my children that is suitable for that implementation.
My idea is thus to create a new kind of datatype which sort of represents "any kind of datatype known to labview" which can be used in functions of a main class that are inherited by its children, which are all using a different input datatype.
ps. Now you could maybe suggest why not use a variant datatype? Yes this is possible but the problem is;
- I would have to cast the data back
- It isn't very neat programming, the variant solution is in my opinion more a kind of hack to make the code work.
pss. Yes but if you would do this... then...
- Yes there are proberbly a few more work arounds thinkable, such as creating two "Valid" VI's one inherited (Valid?), one unique of the child (_Valid?), but these are in my opinion still workarounds and do not really provide the functionality that is needed. Which is pretty common in OOP languages.
psss. if anyone knows a better title for this described idea let me know it!
I would like to be able to right click on any Queue or Notifier (that has been previously setup, i.e. wired) and find all of the Queue or Notifier functions associated with it. Extend the idea to specifically find where these functions are setup and terminated.
In the pictured example, I have been able to easily troubleshoot a problem where someone has released a Notifier in two separate locations...
22266i6DB10B9728172C12
When a folder under source control is added to the VI analyzer the subfolder for version control is inserted too. Lets get around this by allowing patterns for folders (or files too) which should be ignored. So adding ".svn" would solve the problem of files of subversion being checked.
I see three possibilities to save the patterns:
- for each top level folder
- in the configuration file
- globally (not preferred, other users do not get the setting)
(There is a discussion about VI Analyzer and SVN under http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=290839#M290839)
Greetings,
shb
In their current form, Auto-Indexing tunnels only operate on a single dimension of an array.  For example.  If you input a 2D array, through an auto indexing tunnel into a for loop, and display the resulting 1D array in an indicator inside the for loop as below, you will always get the last row.
I'd like to see a feature where you can right-click on the tunnel or something, and set it to auto-index by column, instead of by row, and get the last column instead.20773i86B483107F51CD3820775i651136B201680B64
It could be as simple as an option in the context menu for the auto-indexing tunnel to say "Index by rows" or "Index by columns"  It gets more complex with 3D 4D and moreD arrays, but you could do something like a submenu flyout that says "Index By Dimension" > "1", "2", "3" etc
Option on the build array function to pad concatenated arrays of different sizes with NaN instead of 0.
Currently, the only representation for array indices is I32.  Given that indices can only be positive, and that modern systems are 64-bit, it would seem sensible to make this U64.
Add support to the Vision Development Module for multi-image TIFF files.  Currently the files can be opened but only the first image can be read.
It is a little know feature that "interpolate 1D array" also accepts arrays of xy points. (Here's an example from this post)
However, these days I mostly do xy graphs using complex data (RE=x, IM=y), and it would be useful if "interpolate array" would also accept complex arrays the same way, interpolating IM based on RE, in this case.
Here's similar code (fragment) using complex, but now it's not possible to interpolate the xy data directly because complex is currently not a valid input.
Suggestion:
Similar to xy graphs, interpolate array should accept complex arrays and it would act the same as when an array of xy points is wired to it instead.
I need a vi which will convert PNG file to GIF file. i could find a vi which is not in palette, do this. But the output GIF file is in uncompressed format. So the size of the file is very large. And also it is not working when i build the application as EXE.
It will be really helpful for me if this feature is included in the next release of LV.
Vairamuthu.
I'd like to see native Ternary Logic support (aka three-valued or trivalent logic, or 3VL). True and False could still be represented by 1 and 0 respectively, and the third option could be represented by -1.
Not much else to say about this really... I think it's pretty self-explanatory.
Analagous to replacing wire connections with a Shift Register on a While Loop, it would be nice to replace the connector where a wire enters an In Place structure with one of the appropriate accessor functions (Unbundle/Index etc).  In the same way, it should prompt for the location on the other side of the structure, either to replace a wire connection, or to create a new element.
Via the Historical Data Viewer it is possible to export the citadel data to text (compare screenshot). In many cases it is necessary to export only the real datapoints without interpolation (like the read trace VI supports) to avoid an incorrect representation of the recorded data.
