Community Browser
Top Authors
Post an idea
I need a format into string that is capable to format numeric with thousands separators.
Like this  (Visual Aides - Numeric Separators) idea but also for the conversion and scan functions.
Looking at the syntax
%[$][-][+][#][^][0][Width][.Precision || _SignificantDigits][{Unit}][<Embedded information>]Conversion Code
the  <Embedded information>  currently used only for time formats would be ideal to extend to a more general form.
Something like <+ nnn nnn.ddd ddd> would be nice 🙂 ( the d is already occupied ... # or whatever .... maybe similar to the excel format syntax or maybe there is a (better) standard??? )
Currently I use the attached vi to add the separators, however it would be nice to have it in a general form
I think it would be cool to be able to define custom units in the build unit string function.  For example (%, dB, or Dan's).  The ability to include custom units would remove the burden to include every unit in this dialog.  Adding custom units would also help people who have large complex calculations.
When replacing a normal Add (of a Timestamp and a value) with the compound arithmetic, the Timestamp input gets broken, this should not be the case.
I think everyone under the sun must have written there own degrees to radians function or vice versa.  Its not hard to do but perhaps it should be available natively as part of the maths palette.
There are many array functions that don't need to depend on the dimensionality of the array - for example most of those in the "Probability & Statistics" menu (Mean, Median, Std Deviation etc) and some in the Signal Operation (like Scale, Normalize).  But if I want to use one on a 3D array, I must first make a copy by reshaping to a 1D array, which can be very memory-expensive.  I'd like a node on the "In Place Element Structure" which accepts an array of any dimension, and makes the data available as a 1D array of that type.
I've suggested a similar idea before here, but perhaps I made it too complicated to receive any comments!  I keep running into this problem, so lets try again.  Smiley Happy
Please implement a way to generate reports in ODF (native format of OpenOffice) as it is a file format everybody can read (.doc is not because you must buy Microsoft software).
If you do that, programmers will automatically be able to generate PDF because OpenOffice has a dos command to convert any ODF document to PDF.
LabVIEW  has a somewhat hidden feature built into the variant attributes functionality that easily allows the implementation of high performance associative arrays. As discussed elsewhere, it is implemented as a red-black tree.
I wonder if this functionality could be exposed with a more intuitive set of tools that does not require dummy variants and somewhat obscure VIs hidden deeply in the variant palette (who would ever look there!).
Also, the key is currently restricted to strings (Of course we can flatten anything to strings to make a "name" for a more generalized use of all this).
I imagine a set of associative array tools:
  • Create associative array (key datatype, element datatype)
  • insert key/element pair (replace if key exists)
  • lookup key (index key) to get element
  • read all keys
  • delete key/element
  • delete all keys/elements
  • dump associative array to disk
  • restore associative array from disk
  • destroy associative array
  • ... (I probably forgot a few more)
I am currently writing such a tool set as a high performance cache to avoid duplicate expensive calculations during fitting (Key: flattened input parameters, element: calculated array).
However, I cannot easily write it in a truly generalized way, just as a version targeted for my specific datatype. I've done some casual testing and the variant attribute implementation is crazy fast for lookup and insertion. Somebody at NI really did a fantastic job and it would be great to get more exposure for it.
Example performance: (Key size: 1200bytes, element size 4096: bytes, 10000 elements)
insert: ~60 microseconds
random lookup: ~12 microseconds
(compare with a random lookup using linear search (search array): 10ms average. 1000x slower!)
Thanks!
it would be nice if we could copy teh changes from one vi to another while comparing two VI's
Add CUDA support for analysis, comutation and vision.
Inconsistency is found in the supported image types for many IMAQ vi's:
For instance IMAQ ROIProfile, IMAQ LineProfile and IMAQ LinearAverages supports U8, I16 and SGL format but do not support U16 format images.
But, a profile along a line drawn in a U16 image should make as much sense as in an U8 image. Shouldn't it? So why is it not supported?
In addition, I would expect it to be easy to add an additional polymorphic U16 version.
These are just a few of several examples of similar inconsistency in IMAQ vi's.
Message Edited by heel on 03-17-2010 08:33 AM
I would like to see a LabVIEW implementation of the Matlab function which approximates a floating point number to a ratio of two integers, within a given tolerance.
From Matlab help:
 RAT    Rational approximation.
    [N,D] = RAT(X,tol) returns two integer matrices so that N./D
    is close to X in the sense that abs(N./D - X) <= tol*abs(X).
    The rational approximations are generated by truncating continued
    fraction expansions.   tol = 1.e-6*norm(X(:),1) is the default.
    S = RAT(X) or RAT(X,tol) returns the continued fraction
    representation as a string.
Some discussion and example code of how to implement in LabVIEW is here: http://forums.ni.com/ni/board/message?board.id=170&thread.id=18012&view=by_date_ascending&page=2
Is there any reason why backwards compatibility couldn't be added to the LabVIEW datalog access VIs?
Why does a LabVIEW 8.x (or 7, or 6, or 5, or 4, or 3) datalog file NEED to be converted to LabVIEW 2009 datalog format.
 Shouldn't it be optional?
I have around 8 terabytes of data in LabVIEW 7 and 8 formats.  Switching to version 2009 will be very painful (as was the switch to other versions), in that it requires me to convert each datalog file.
- yes I know about SilentDatalogConvert, yes I could write a simple program to churn through all my data files. That much data would take weeks or months of continuous chugging - seems silly.
I'd even settle for backwards compatibility with caveats - read-only for example.
The Cluster type of my datalog file hasn't changed in 15 years. Maybe a cluster type check first to determine if the format really requires an update, but even then allow access without conversion
If you have messy "future" or "obsolete but we are being risk-averse and keeping it around" code in the Disabled state of a Diagram Disable structure, VI Analyzer reports test failures for such code, in my opinion cluttering results.  It would be great to have an option, perhaps in the "Select Tests" page of the setup wizard, to ignore any such code.
We have a Round towards -Infinity  (3.8 becomes 3,  -3.8 becomes -4)
We have a Round towards +Infinity (3.2 becomes 4, -3.2 becomes 3)
We have a Round to Nearest (Rounds up or down to nearest integer, if 0.5, banker's rounding to even integer)
Why is there no Round towards Zero?  Basically a truncate.  (3.2 becomes 3, -3.2 becomes -3)
I have a use for that right now, but it takes several primitives to work.
As a corollary, a Round Away from Zero.  (3.2 becomes 4, -3.2 becomes -4)
Message Edited by Ravens Fan on 01-19-2010 04:53 PM
To make your code reusable as subvi's and have less connector space used the cluster is a way to go, but you need to define the types inside your cluster upfront.
If you want to add an other item inside this cluster you have to rewrite all the subvi's this cluster is wired to...... This is at least annoying. (or dull, boring, dreadful, tedious, dreary, tiresome, aggravating, exasperating, irritating)
If you could add new types of variables inside this "Dynamic Cluster Array" on the fly, you can expand the clusters on the fly when needed !
Example of a "Dynamic Cluster Array":
 Look also to the Search 1D node, to see how you can select an array cluster item.
You can read and write the cluster as normal clusters but if you want to read or write a variable that does not exist this variable is added.
Reading and writing this variable will add this variable in all clusters in the array, these variables will get the default value until your software changes this value.
This behavior is the same as structures in Matlab
John
Background:
LabVIEW has had a recent proliferation of datatypes that essentially store the same type of data: an ordered sequence of numbers.  We now have Array, Matrix, Waveform (+ Digital Data/Waveforms), Signal (!) and Image datatypes (and perhaps one could also include Scalar).
The Benefits:
Each datatype is optimised for its own particular application, making it simple to perform a particular set of operations on the data.  However each appears to be developed independently.
The Limitations:
Each datatype has different restrictions on representation, dimension (typically only 1D or 2D), and "metadata", and most built-in functions will work on only a small subset of types.  Accessing the data as a different type usually requires copying the underlying data, with consequent limitations on speed and especially memory.  I notice these limits especially in three situations:
1) I want to use a function written for one datatype on another datatype (for example, use the Wavelet Denoising function (or even simply Square Root) on an Image),
2) I want a way to work easily with 3D images (most of the existing 2D image processing functions would have simple extensions to 3D),
3) I want to write routines that will adapt to both 2D and 3D arrays (say deconvolution).
It is certainly possible currently to work around all of these things, but it seems there should be a more cohesive approach.
New LabVIEW developments:
3 new developments in recent versions of LabVIEW show potential for addressing this issue: Classes, In Place Element Structure, and Data Value References (DVR).  However because they are all ideas "in development", and added on top of the existing LabVIEW rather than under the core, they only hint at possibilities rather than provide them.
A Possible Solution:
A low-level generic Array datatype from which all these other types are "inherited", therefore providing a single common way of addressing array-type data.  It seems like this datatype could resemble either a Class or a DVR.  It would have various attributes associated with it:
- Dimension and Size - essentially specifies the way in which indices address the array (probably always stored as a 1D array underneath)
- Metadata - e.g. t0 and dt of Waveforms, name etc of Signals, border size etc of Images, ...
The In Place Element Structure would be one way of choosing how to access the information in this variable, although it may be possible for the array information to be directly available.  Hopefully something like this would also enable the ability to "overload" existing routines, for example adding a 3D convolution to the 2D and 1D routines that already exist.
Some of my earlier thoughts are here, here and here.
PS - hope no-one said Ideas here had to be practical or reasonable!
HiSmiley Happy
It is clear from the title itself what i want to say.
When are we going to see a function in the functions palette through which we can directly view the Excel file as an array in labVIEW!!! Everytime building a code using ActiveX and the property/invoke nodes is not comfortable.
If the excel file has more than one work sheets, then the user must be able to select the desired worksheet. It should be able to display both 1D and 2D arrays
Also, if the Excel file contains some graph or chart, It should scan for it and display the same. This would be the set by the user weather the function should search for the graph or chart. It should return the  graph/ chart in the form of cluster (in case the sheet has more than 1 graph/chart):smileyhappy:
Attached is the pic of the proposed function with labels
This would replicate the ability of the standard Index Array function to extract a subarray from a multi-dimensional array. Currently both indices must be wired, which only selects scalar elements.
Another related enhancement that may be useful is to provide the equivalent of "Array Subset" on the In Place Element Structure.
there have been several ideas on the forums pertaining to making labview smarter about how it handles arrays, but none of them (that i've been able to find) quite get to the root cause: labview doesn't directly support a 'sorted' status of arrays.
labview should add a 'sorted' field to the array data. when the array primitives detect, either at runtime or compile time, that an array is or could be sorted, it generates optimized code. for the most part primitives will function the same but just be more efficient (e.g. array min/max will be constant time operations).
the special cases for this feature are the array building and modifying primitives because i believe they will need special behavior in some cases to make sorted arrays useful.
build array  when all input arrays are sorted, the output array will be sorted. this seemed strange to me at first, but the more i thought about it, the better this seemed as the default behavior.
insert into array  when the input array is sorted and the index is unwired, the output will be sorted. this will be true whether or not the insertion is one element or an array of (possible unsorted) elements.
i would assume you could turn any of these behaviors off by right-clicking on the node and configuring it. i'm sure the labview team can figure out mutation issues as necessary.
