Community Browser
Top Authors
Post an idea
Using the LabVIEW 2009 Build Spec (as an example) allows you to add a Destination to a Library which is very handy, as it means you can namespace VIs at build-time.
I would like to take this a step forward and then be able to set that new Library as a Sub-Library of another Library that already exists in the Project.
I would then want to be able to set the scope of this Sub-Library as well (relative to its now, Parent).
This combined with my Locking State Idea would allow be create a Distribution that would hide and protect a Support VI Library
As the Sub-Library would be Private Scoped (from above) and the Parent Library would be set Locked (does not show Private Members).
I currently can implement this using Scripting but it would be nice to have it native.
Cheers
-JG
17619iFB1C3A1375DBE39317621i6935DFDFCA489040
Create a VI to read the config from string instead from a file for in memory configuration.
Also create a VI to read out the config as string.
Regards
Marc
in LV2009 a new set of VIs have been published for working with configuration VIs. They are now part of config.lvlib. But some VIs of config.lvlib are marked private, therefore I cannot use these VIs as Sub-VIs, if the calling VI is not part of config.lvlib. This is bad (at least for me), since I have written some tools to load a configuration directly from a string and not from a file. To do this in LV2009, I need these private VIs, which I cannot use without changing config.lvlib.
Therefore I suggest to make all VIs of config.lvlib public. In fact, is there a good reason, why these are private in the first place?
Marc
The Lego NXT software release (not toolkit) is a wonderful interactive environment, that should be provided as an add-on application
on its own, call it "block application builder".  I see many useful applications in a variety of different industries where businesses wish to extend to their customers interactive and intuitive interface that they can program in their desired configuration of the product's behavior according to their own use cases.
That means we need an environment where we can prepackage blocks that is functionally specific to their applications, with ability to sequence them, run them in parallel, add conditional runs, and iterative loops. The blocks themselves could be computational in nature, or additionally provide user interface popups for interrogating the user, and have access to the full range of Labview functionality. Each block properties settings can appear as front panel settings for user to customize the behavior of that block. This is exactly how the
Log mindstorm software was configured, except we ask that you extend the availability of that functionality for the general users to develop their own intuitive applications using the same environment framework design. This application can target building the customer created sequence of operations as a windows .exe or .dll. We also would like to customize the menus in the application. In other  words, make the Lego mindstorm application a generic template for us to develop our own applications with similar intuitive framework.
This post
Has gotten me thinking about how to handle preserving a memory location for external data updates.  @009 has much better memory management- couldn't a Preserve Memory primitive be written? For obvious reasons a counterpart Deallocate would need to be required for each "Preserve" call
