Community Browser
Top Authors
Post an idea
Report Writer BEFORE WIndows 10 was SUPER ROBUST! Now that Windows 10 came along there exist many "turds" left in the Registry when folks UPGRADE from Office 7 to Office 10.
What happens is the Registry NEVER NEEDED to be kept clean of extra junk because NOBODY EVER UPDATED Office.
Now every Joe on the planet updates their Windows 10 with the latest Office 10..
What happens if they do NOT FIRST UNINSTALL, is the Registry is left with "turds"
When Report Writer uses ActiveX to make calls to use Word, in the old days, there was a SINGLE key in the registry to allow the calling program to gracefully start Word or Excel, or whatever.
NOW< with Windows 10 there are FREQUENTLY multiple "keys" in a Registry that causxe the LabVIEW Report Writer to "Gag" and "Hang up" doing nothing.
The SOLUTION is for the Report Writer to PARSE the Registry for valid keys and allow the request to be passed to the propper called process.
If this is not clear, please look up the SR below. There are a TON of examples and videos explaining how to fix it.
I have been working with LV since Dr. G was roaming the halls on LV 3...
This is the FIRST TIME Report Writer has gotten "sick".
This is an EASY FIX for the devs and since Report Writer is a purchased plugin they sould be able to update it so it works well.
Currently, they have us fiddling with the Registry or telling customers to uninstall and reinstall Office. That is a BIG FAT NO-NO to big companies because Office WORKS COMPLETELY for them and even programs like SolidWorks and DXP that use Word and Excel for stuff.
My number 831-455-0418
DEVS:
Please see: Request #: 00994109] Can not get EXE BUilder to run on WIn 10
it would be great if adobe reader was built into the additional installers section of the project installer build.
i would think this would be a common thing users end up installing sperately
Idea is quite simple - add to instrument drivers project wizard template for switch/MUX/matrix devices.
Custom switching boards are commonly used, b/c for some simple purposes it is cheaper to make custom design with simple functionality (some micro processor which controls relays), and which could communicate by serial line. Then instrument driver - is ideal solution to create simple API in LabVIEW for its control; but unfortunately, there is no template for such types of devices in New Instrument Driver project wizard.
Hello Guys,
as we are transforming our Testing Application deployed as Executables to something more "state-of-the-art", I found the Remote Panels solution could suite our needs.
Remote Panels are a nice solution, but they rely on LabView RTE and Browser Plugin on the Client Machine. I don't think this is state-of-the-art, since the Web Technologies Wars have are over and Plugins lost the Fight.
I found some similar ideas in the Idea exchange, but none of them hit the point directly. So heres my Proposal:
Replace the reliance on LabView RTE and Browser Plugin with a HTML 5,JavaScript and Websockets solution, that runs on any modern Webbrowser!
This would bring the following Advantages:
- support for any client operating system (even IOS, Android, etc. possible)
- seamless support for Remote Panels in modern browsers (neither Chrome, Firefox, IE will support NPAPI in the future)
- take advantage of all the PROS of modern web technology (e.g. responsive UI to support Touch UI targets)
- since no Plugin is needed, Clients will have no Security concerns (remember Adobe Flash concerns at Apple)
- no need for any NI customer to build an own HTML5 remote panel solution to bridge this obvious gap of Labview Functionality.
I know there are solutions for Windows Remote Control like VNC, but this does not offer a target UI adjustment for the application. So for example a Ipad Target will not change its UI to be Touch-friendly for the User.
I hope you support the Idea! Best regards and thanks for the Attention, Philipp
To generate a VI or set of VIs with a general driver to get low-end FPGA boards to work with LabView FPGA. Parameters will only come from the users to make this dynamic, this would be the total count of I/Os FPGA type, location of I/O items (eg. buttons) in the FPGA board, etc. It would be a bit of work, but also would pay off at the end. Doing such is no more than an extension of LabView if done well, let's say written in an xml file plus it would be a very powerful tool for researchers, and would generate more sales to use LabView FPGA for more researchers, university students, and engineers who want to test a few things without full initial commitment to NI tools.
It would be nice to get the Test Case Comment into the report. Also, please add programmatic access to read it out.
Hi
Is it possible that the contents within the instr.lib to be defaulted to read-only every time LabVIEW launches? VIs that is drag-drop from the pallet onto block diagram is currently modifiable and may cause unintentional code modifications, especially due to the 'save all' function and hasty/improper shutdown. The extend of the damage may be inherited over time.
Also propose to default modified instr.lib VIs saves to be in active project folder instead of the instr.lib.
Hope to see these features in future versions.
Make a tool pallete wizard that would make it easy to install custom software into the tool pallete. It should allow for the user to make the sub directories, Icons and everything that is need so it could be published without have all kinds of headaches. Making tool pallete menus has to be one of the worst things I have to do. This year with the FIRST libraries being added to the tool pallete a lot of them have no icons because of how hard this is. PLEASE make this easier to do!!!!
There are some analytic software that adds connections to Excel.  JMP comes to mind - it allows 2-way data transfer, and allows excel to run some of JMP's analysis routines.  Those packaged routines are vetted by phd's and can't be quickly damaged by a tired user.
This details how JP morgan lost a few billion dollars because they were using Excel for hard math, and someone had an error in an equation.
Excel is likely more common than both Javascript or SQL for use in the planet.
It might be very powerful to be able to import an excel spreadsheet, specify inputs, specify outputs, and get it translated to "g".  This could allow it to run thousands of times faster, and the visual language would allow a technical vetting that can be very hard for humans to do on hundreds and hundreds of pages of tables of numbers or formulas.
This would be a motive for banks like JP Morgan (or their peers) and their multi-billion dollar business units to use LabVIEW.  Stunning speed, optimization, and scale.  Stunning accessibility to error correction.  Packages that, once wrapped, stay wrapped, but can plug in where they need to.
Other add-in or connectors for Excel:
It is unlike the TDM-importer in that it sends data to LabVIEW, the data is transformed or processed, and a numeric, text, or image result is returned to Excel.
GPS/INS applications are increasing every day as you know.
It is inevitable that using maps in GPS/INS project.
There is not a simple and useful map tool in Labview.
In some open source code map applications like "Open Street Map" will be useful for some projects which including GPS/INS.
I've made my own copy of the actor framework to implement some changes that I really needed. Because of this I cannot really share code easily and my framework branch is not automatically updated. The changes that I've made could be made without overwriting the framework if only the framework was more open.
(a bit of what you can do with the changes are listed in brackets)
Creating more functionality for actor framework classes should be done through children of the classes in the framework. The way the framework is setup makes it impossible to add functionality to some classes:
- Message Priority Queue
- Message Enqueuer
- Message Dequeuer
- Message Queue
These classes are all obtained with a class constant internally in the framework.
I would really like it if we could have a class input to all these so we can implent additional queue functionality and have this input as part of either an actor dynamic method inside of the Actor.vi that the constants are read from or an input to the launch VIs.
[Magic can be done with enqueue in front combined with batch message children and public scoped read self enqueuer --> self propagating message array]
Changing functionality through dynamic dispatch is the way it's meant to be done. But most of the Actor framework VIs are static dispatch. Vi's that I'd like to make dynamic are:
- Launch Actor Core.vi (and probably all the other launchers as well)
- Actor.vi
- Send Message and Wait For Response
- Send Batch (Or change the class constant to a control
[adding a counter to an actor child would be easy with a dynamic dispatch of Launch Actor Core]
Heavy use of access scopes makes some actions impossible (as intended). I'd like to have the following changed to community scope and added as friends to the Message class:
- Read Self Enqueuer
- Read Caller Enqueuer
[Messages that flush the queue, view the queue status enqueues them self on the queue and so on can be made]
And lastly but surely the most controversial is the change of pre launch init from non-reentrant to reentrant.
Yes by doing this and launching an actor from within the vi will crash your program. But doing it as is will result in a deadlock anyway. The protection of making it non-reentrant is extremly weak! I'd rather have some warnings. What you gain is that the actor that you are launching and the nested actors that it will launch from the pre launch init can share their private data during launch! This is extremely useful with actor shared notifiers, DVRs and so on. Note that you can do this halfway by launching from the actor core.vi however the data will only be shared up in the hierarchy not throughout the entire hierarchy... which is bad/sad.
I hope you'll look into at least some of this to enable a more dynamic usage of the framework for advanced users.
Add a LabVIEW application method or property that would allow us to set the object of the context help so that we can specify a VI from a tree based browser (much like the Project Window does).
https://lavag.org/topic/9167-context-help-for-a-vi-without-loading/?p=54820
LeCroy oscilloscopes do have a decicated area of the user interface for customization. The custom space can be used by an ocx-ActiveDSO PlugIn that is registred on the instrument.
This kind of ActiveX-Control can do far only be built by some VC and VB compilers.
It would be very nice to build now such a CustomDSO PlugIn for a LeCroy oscilloscope by LabVIEW.
With regards
Peter
Tameq Schweiz GmbH
+41 56 535 74 29
A version control system is a must these days, but rearranging project files in LabVIEW is a nightmare without integrated support.
The correct way to do things is in LabVIEW rather than the file manager to save creating headaches and conflicts in LabVIEW.
The correct way to do things to maintain subversion history and minimise headaches related to subversion is in the file manager using subversion tools (e.g. TortoiseSVN).
So without subversion integration, we are damned either way.
Please provide a way we can get this support without doubling the cost of all our licenses by upgrading to Professional for this one feature (management will never go for it) . Please consider adding it to cheaper versions, or at least make it available as an optional addon for a reasonable price.
Can we have some report generation that is Microsoft Publisher specific as this would be more useful than word or excel. Or a more generic format that could be used by different publishers. Or a generic print file that is more adaptable to the page size and position on the page. LabVIEW desktop publisher?? This is because the only way to print at the moment is via word or excel or by printing the front panel which can be a bit hit and miss in different versions of Windows.
It would be very useful if we could have same QuickDrop PlugIn with the same shortcut depending of the selection object that we have made in "Block Diagram" or in "Front Panel".
For example:
- Imagine "Ctrl+C" short cut, this would be useful for lots of QuickDrops that comes to my mind.
  • Copying to clipboard a bundle by name text.
  • Copying to clipboard a unbundle by name text
  • Copying to clipboard a selected case.
  • etc....
i have an idea to use for labview for vehicle navigation display on ENC charts. it will be very useful as developing sensor interfacing and acquiring data from navigational sensors (GPS , accelerometer, gyros ) is a lot easier in Labview but then displaying it properly using ENC charts for mapping purpose is still a question mark in Labview.
i would like to refer some companies (global mapper etc) which are developing SDK  and activex control for C# etc but no support for labview.
Although there is a manual patch for that I think that it will be nice to include the VI Snippet for chrome users too.
Hi!
We are trying to work with an OPC server with some array tags defined. We can access the array tags perfectly.
If you request a single value from that OPC server (through an OPC client like Wonderware, Ifix, Control Maestro (Wizcon), WinCC, etc….), the OPC server sends a timestamp with the time in which that value was acquired. I have confirmed that there's no way to request single values from an array tag (neither with DSC, nor with DataSocket).
I don't know how hard to develop would this feature be, but I think it would be great.
Regards!!
This is a suggestion a bit technical and is posted here following the suggestion of the National Instruments support center.
When building a shared library from a vi, the run time engine make use of a configuration file which has the following name: <name of the executable program which links in the DLL>.ini .
The fact that the name of this file is not configurable by the users is EXTREMELY annoying in my application (the LV DLL is a plug-in of third party software) because causes the corruption of the calling program configuration file.
It seems very easy to me solving this problem by making user-selectable the name of the ini file used by the DLL produced by LV. It also would improve the interoperability of LV with third party software.
I really hope to see this upgrade already in the next release of the software.
Thank you very much.
