Community Browser
Post an idea
Labview should support inserting a LabView plot object in microsoft powerpoint to allow access to the data and plot features like enable disable in plots that have been shared via powerpoint. Many other applications support embedding their objects in powerpoint.
provide a means to see dotnet or externall dll documentation in Labview
Ie
        /// <summary>
        /// the file location where the data is to be logged.
        /// </summary>
        private string _path;
        /// <summary>
        /// </summary>
        public string Path
            set { _path = value; }
ie to be able to see the following
when the property node is touched In labview
I very much like being able to export a labview.vi to a .dll or .net interop library .dll. Our higher level automation is in C# and having access to labview.vi via .net .dll is great. However, the current build capability only allows a single prototype/method to be created. Consequently, I have to provide every input/output when invoking this single method. This can work but it's just inconvenient and not as obvious as being able to create multiple methods smaller things, e.g.
write setup values
write DAQ sample rates
start storing samples
stop storing samples
stop DAQs
write summary info
When I create a C# class, I can create any number of methods or properties to manipulate class data members. Exported labview.vi files should enable this too. NI AE said I could create parent.vi files (setup.vi, write_DAQ.vi, etc) that all include the actual vi of interest. These various vis could be added to the exported .vi list. And, this would indeed be a work around. But, this is a hack to get around this problem and the AE agreed. Instead, I would like to be able to define multiple methods/prototypes on a single exported .vi.
I am communicating to parker motor controllers through the Ethernet (parker sample code). Apparently since it is Ethernet based, the code uses socket, where the sockets require admin rights (another discussion about ethernet based and admin rights). In order for my VI to connect to the controller I need to run LabView as an administrator. The problem is I am making this program into an executable for production work.
When I create the executable it will not connect to the controller unless I am running the application as an administrator. As this program will be used in production I want it to be as simple as possible to perform. I don't think there is a simple way to change the environment to run without the need to run application as an admin. Are there any ideas to either change the executable to run as an administrator through the application builder? My plan is to create an installer through the application builder.
Some ideas that I had is to create an installer file and create the executable. Change the privilege level of the executable (properties>compatibility>privilege level>run this program as an administrator). Use a batch file to install drivers and application, then replace application with the one with the elevated privilege level. Another idea I had is use a batch file to do a runas command to run application as an admin. I cannot get either method to work. Does anyone have ideas?
Greetings,
I recently took the NI Instrument Control class and we came to the topic of creating a VI tree.vi.
It didn't make sense that we needed to update the VI tree.vi AND the palette when we add or delete a VI.
I propose that there should be an option to auto-make a VI tree.vi or just a simple html page with the available VI's in your project/driver.
This currently makes sense since all the VIs should already be categorized in the palette.
-Jose
Many times when wanting to share a VI Snippet on a discussion forum to quickly demonstrate a suggestion, I find it tedious to save the snippet to a temporary location, then go to the webpage, navigate to the location and upload the image to add it to my reply.  I think it would be very helpful to have the ability to configure the VI Snippet to automatically upload to an online image host (imgur.com for example or even an NI solution) and put the link on the clipboard.  Then it's ready to paste into the reply.  Other desktop screenshot applications already have this functionality (see ShareX (formerly ZScreen) ).  The purpose of VI Snippets is largely to facilitate this exchange of small portions of code and this would simplify the process greatly.
Every time when the new Developer Suite arrives, we have to setup our development system from ground up.
This could be simplified by installing OpenG right from the Platform-DVD's.
Also, the risk of missing dependencies between systems will be dramatically decreased.
Being able the Dialog "Search Results" from custom tools would be nice.
This could be done by providing an API to the real search dialog or by placing a VI for showing a similar looking dialog into vi.lib.
The Idea has been mentioned here: https://decibel.ni.com/content/message/15984
Most of the time the only part of a VI that needs protection is the block diagram but there are a few instances of why including the front panel in the password-protection would be needed. Someone can see the front panel of a subVI during run-time even if it is under layers of password-protected subVIs.
For instance, an encryption application. Except for the Top Level VI, all other VI's are password-protected.
During run-time, the Key for the encryption algorithm, which should never be known, is shown on the front panel of the Key Generation VI as well as the Encryption SubVI.
Of course one work around for this would be to hide all items on the front panel of each subVI but this will slow down further development in the future. The ability to just type in a password would allow a developer to instantly return to work.
Also, an alternative solution would be to allow password-protected Source Distributions.
Can anyone else think of an application in which the front panel of a VI should be password-protected?
Other Notes:
It is important to mention that it is possible to do things like Remove the Front Panel or Remove the Block Diagram, but this does not allow the VI to be recompiled for different targets. This is why a password-protected Source Distribution would be ideal.
The 'Context Help' window shows the use of each connection for a sub-vi, but in a multi-developer environment, opening a sub-vi is often necessary - especially for math & data analysis.
How about a button (selection like 'lock context help') in Context Help that enables the display of block diagram of the sub-vi below the connector pane?
Also, the author of sub-vi could pre-decide what part to include in this 'Context image' instead of complete diagram, thereby suppressing trivial parts.
Hi
it would be great if there would be a better platform for 3rd party VIs, for example instrument drivers. Something that allows you to see when the last updates where done, what has been changed (browse the code) and also something that would allow you to branch from the existing code, add changes and sent a pull request back in a way that other people can see that the VI has been branched, so that they don't need to duplicate their effort.Including an issue tracker with this would also be great.
This in my view provides faster turnaround for fixing bugs and adding new features. I had to fix a few bugs in some drivers, emailed the VI back to NI and since then nothing has happened to the driver at the least the last few times I checked and there is not a good way of tracking this. The idea is not new and there are lots of platforms like this around in the open source world. Here are some examples:
github http://github.com (version controlled history, branching, merging, issue tracker, per project wiki)
bitbucket http://bitbucket.org/ (similar to github)
Lots of linux distributions manage their source code this way:
OpenSUSE build server: http://build.opensuse.com (version controlled history, branching, merging)
Launchpad https://launchpad.net/ (version controlled history, branching, merging, issue tracker, code review, translation)
and there are plenty of other sites.
For Reports it is only possible to set one with for all columns. It would be nice if the polimorphic VI "Append Table to Report.vi" would support column with for multiple columns too. Several VIs would have to be copied and adapted.
For a standard report, the VI replacing "Set Table Column With.vi" would look like this:
The functionality to adapt to the page with if the column with is too big is lost when different withs are set. But probably NI could fix this too.
Greetings,
shb
Locking a library during an automated build seems like a very natural thing to do.  Would be nice to be able to script it.
Create a VI, which allows to get the config file path from the config reference.
Marc
In my project, I wanted to set the cell color in excel as red during a failure condition. But to my surprise I found that the color was set to blue and NOT red.It took me a long time to understand that the hexadecimal values for the color constants are different in Labview and MS Excel.
I wonder why the color constants are not standardised, when Labview supports features like ActiveX controls.
In LabVIEW, we can create a polymorphic VI, but polymorphic VIs are made by creating multiple disparate VIs and logically tying them together. What I'm proposing is a single VI which can be used to perform many different functions, as is normal in many text languages.
Imagine a class with 10 different functions, and the ability to read/write from each. We'd have 20 similar VIs. I propose a single VI with a tabbed front panel. When you select a different tab, you'd see a different block diagram. Each could have a different connector pane. When saved, it would create a single file. On a palette, it would be a single function. We could use a polymorphic selector to choose which function to operate on.
This would simplify distribution of classes and drivers.
I'm proposing a new certification, one certification to rule them all, the Certified LabVIEW Gangster Group Developer.
Or simply a fully functioning CLA that requires 3 people to take the test.
Architect
Developer
Embedded Developer
It should function using an FPGA, or a simulated interface.
One of the things LabVIEW is best at is its innate parallelism. Parallelizing for loops with a right-click is something other languages wish they had. Having all code on the block diagram (or equivalent) innately run in parallel is something few other languages have even tried, much less succeeded at.
Crunching large datasets can be sped up through use of GPUs, and over the past decade or more, Nvidia has kept their promise of having a common interface to their hardware through CUDA.
Having a LabVIEW add-on that is well maintained, and that can give GPU parallelism in the same ways we've seen LabVIEW deliver CPU parallelism would be a game changer for many labs and manufacturing environments. It could also help LabVIEW be a leader in the AI space.
I suggest that you create this add on package using CUDA as the underlying GPU calls, in order to keep the code easy to manage, while also providing the package for a large number of supported GPUs.
to transform existing VI to be integrated into PA flows, the drop-in should be populate all controls and indicators to be used as connector variables.
Companies around the world are trying to make it easy for robotics, for example NVIDIA is doing everything that they could get into simulation and and NI should have been in the front to support, just like NI had the tools for mobile interface in 80's, and never released to the public, if it would have happened then Android would not have born, just like that robotics once NI loses it to NVIDIA and python and other tools, it would be difficult so I am trying to create a simulation environment just like digit twin for robotics, where labview will simulate in open source for Gazebo, and then based on the simulation will control the actual robot.
Setup LabVIEW talking to Gazebo through ROS, if you are interested to be part of a group where we could get the software updated, please email me at jacobs.mathews@gmail.com
