Community Browser
Top Authors
Post an idea
I've recently been handed the task to reevaluate our NI licensing needs.  We're currently using a DevSuite setup, with some add on modules and sourcing wants me to evaluate a setup with Labview Professional and the associated add on modules.
Now I have a large code base to check and it would be good if there were a tool which would automatically tell me which add-on modules are used in a specific project.  It could be a menu selection in the tools menu called "List Used Add-On Modules" that checks the project for vi's from add-on modules and lists these.
Br,
Albert Lederer
It's not secret that .NET or ActiveX object on front panel appears to be child window of NI container clipping window, which itself is a child of front panel window. When there's only one object in the container on FP, it is easy to get its window handle (HWND) by calling GetTopWindow or simply by iterating through all child windows of FP. This handle has to-one correspondence with automation refnum on block diagram. But when there are several .NET/ActiveX objects on the panel, it's impossible to identify their handles with refnums on BD.
The way of handle obtainment could be implemented by any of the following methods:
1.
Autorefnum To HWND.vi
2.
 Window Handle Property
(or let it be private property, being activated with special *.ini key)
3.
MgErr AutoRefNumToHWND(refNum, hwndp); - this variant is analogue of LabVIEW Manager function FRefNumToFD, where refNum is automation refnum of .NET/ActiveX object (type LVRefNum) and hwndp is pointer to child window handle (type HWND *).
Probably many people may consider this idea unimportant, but when it comes to drawing different shapes, displaying text, copying window content etc., my suggestion may be very relevant.
Presently LabVIEW and it's toolkits ship with a number examples.  At the same time there is a massive amount of information and examples with content like the examples and the things that are much more.  When I am searching for an example I often can't remember if I saw it on the web or in the examples.  So first I open the Example Finder, a tool that I really like, and search for things there.  Then if I don't find what I am looking for there I open up a web browser and search the NI Communities, then the NI forums and other forums (like LAVAG.org).  It would be nice that instead of having to use to programs the Example Finder could give a list of possibly related items on the NI forums.  I think this could be managed using the existing tagging feature of the forums with perhaps by having an #example_code tag.  A crawler program could then parse though the tags and grab the links to pages of possible matches populating a database.  Then this database could be access by the Example Finder for related info.
Another option would be for me to be able to find a link I like and attach it to my example finder or perhaps to my NI.com community account.  That would be useful.
Actuallly, if there was an API for example finder that'd work too.
what does the community think about configurable automatic type conversion between .NET and LabVIEW? We need to deal with a .NET API for a sensor which handles system time with nanoseconds since the 16th century. Don't know why they're doing this stuff.
To set the appropriate time you have to substract two .NET DateTimes. Everybody will know this will look like in LabVIEW.
TS01
You will have to use a method of the object to substract this. Now you're using DateTime.Substract. This means in LabVIEW.
TS02
Here it would be nice to have a checkable item in the right-click run-time menu for the invoke / property node to select or deselect the automatic type conversion so that the Substract() method would accept a DateTime class and not a LabVIEW timestamp.
TS03
Hope the idea is clear enough. I've checked the idea forum for this entry but didn't found it. If so, don't shoot me for a double post.
Tyler.
When using dll's or .Net assemblies, you always have to right click & hunt down which version gets used for the constructor.
It'd be handy to have the version shown in the Help. I already know it's a constructor node, that's not much help...
I would prefer better and much more error messages in the DLL import assistant.
- I had a unknown data type of I64 as "long long". But LabView only knows "__int64".
The only message was "could not import function xxx"
I prefer the line of header file, there the import stopps. Two days of searching, and only small hints from the NI support...
Peter
Property nodes for LVClasses are a tease, this is what I really want:
Invoke nodes that correctly wire call dynamic dispatch by value VIs (this includes the ugly wireing of the "preserve runtime class" inside the in place element structure.  Its ugly, just obfuscate it for me.
References to Data value references that correctly respond can use the "to more generic" and "to more specific" class so that I have the DVR to the more specific.generic class REFERENCE.
Justification for Invoke nodes:
I work with lots of different Classes, and libraries.  I can quick drop alot, but I do not know all the publicly exposed functions in a give class especially since 90% of the time it is still in development.  Generally a pallete won't see the light of day in internal development (somewhat of a pain to make/maintain, definately not a single click operation), so getting the correct methods involves paging back and forth between the project explorer, this is slow.  I want to code quickly, if I can have the Public api exposed by an invoke node it means I dont' ever have to make a pallete of VIs (we can argue over this all you want, it just isn't simple/fast enough)  and I can access the functions much more easily/quickly.  Even if every class had a pallete, it would still be inferior to the invoke node solution because A.) I have to remember where every pallete is. B.) Sharing/installing pallete changes for other developers is PAINFUL.  I want to give them a zip file that they can chuck anywhere.  I sure do not want to make a scripting function to update there palletes, so it requires file moving/installation/making sure they actually put the class in the right folder (which someone will always do wrong and invariable cause me to right arrow enter 1000 times when I receive their project.)
It would be nice if you can define a webpage or email address for bug reporting in a VI or library, that you could set under File->VI Properties before you distribute a library/device driver, etc.
If this address is set, labview could automatically add a menu entry "Report Bug/Feature Request" in the Help menu that takes you to a webbrowser or a email client with some preforumlated text, e.g. subject: "[Labview Bug Report] <VI name> <VI version>".
This way one wouldn't have to start browsing the web frist to figure out where to report problems.
It would also be nice, if one could set this once for a complete project and all VI would inherit this from the project they belong to.
regards
Arun
LabVIEW has shipped with an Express VI which supports the ASCII LVM format since version 7.0.  However, there is no other way to access LVM files from LabVIEW, short of burrowing into the Express VI and using the subVIs.  Doing this leads to problems, since the subVIs have changed a few times.  In addition, the Express VI does not support all the features of LVM and makes accessing multiple data segments somewhat nonintuitive.  We need an API for LVM, ideally object based, so features like the special block can be easily extended by users.
We are getting into trouble with all these run-time engine updates! Every time a new release or service pack come out we have to create a new installer with the new run-time engine and send it out onto all our customer's machines. It is not convenient to develop in 20 different versions of Labview and we like to keep our executables and updates recent.
Our instruments run on XPe with very little extra room for an additional RTE every 6 months. Asking the customer to uninstall old RTEs is painful as they are not supposed to go that deep inot our XPe build.
I would like to see a modularized run-time engine where we don't need to update the whole thing every release. I know  with .NET updates are only necessary in 3-5 year increments. That would be much more acceptable IMHO:smileyhappy:
For projects, libraries, and their associated files, if the "Save Version" property is set to an earlier version of LabVIEW, the project and its files are not recompiled to the editor version.  There should be an option on the Mass Compile dialog that allows the "Save Version" property of projects, libraries, and classes to be overridden.
It would be great if Package builds also supported these two arguments as is supported by normal installers Advanced Page (Installer Properties Dialog Box) - NI
The value in this, is that you could then store your package feed in a directory that is relative to the package and automate installing the package and adding the feed to NIPM.
Currently, as per NI support, there is NO way to do that.
I haven't tried yet, but this might be already possible by generating C code and then building a Python package from that. It would be nice to have that automated.
I think there's also a commercial potential to sell Vision Assistant as a separate product (to Python developers).
It would be great to be able to configure LVMerge options via the command line as described here
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q0000019c3VCAQ&l=en-US
There was a previous proposal to fix this that was closed
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/LVMerge-Configurable-Load-Options/idi-p/1282252
Please kudos this so that that it is considered 😉
When integrating libraries written in C# a common scenario that occurs is the necessity to cast a method to a generic delegate defined in the class in order to, for instance, subscribe callbacks to events belonging to sub-classes inherited by the object instantiated by the Constructor Node.
So far LabVIEW efficiently allows to subscribe to events, registering a VI as callback in case the event involved is fired, but does not allow to cast a VI to a generic delegate and that's very limiting.
The only workaround existing is to wrap the C# library, adding an additional C# layer that instantiates the delegates on behalf of LabVIEW and then exposes plain methods, properties and events that are straightly callable by LabVIEW itself.
The idea is to allow  LabVIEW to instantiate generic delegates based on the definition of the delegate provided by the C# library and return the delegate object so that it can be provided as input to library's methods requesting it.
This feature would make the LabVIEW integration of C# dlls more solid and completely manageable within LabVIEW code without further wrappers needed.
Just recently ran into an issue with XML namespaces where the LabVIEW implementation just didn't cut it. The AE had R&D confirm this too. The work around, after trolling through the vast sea of .NET XML features & forums, was there. Something this simple shouldn't burn up this much time.
The world around us uses JSON & XML extensively yet the examples are minuscule. It doesn't matter if new examples are .NET, Python or something else but we need to get to solutions quicker.
I just had a call with a customer that have a problem:
we cannot install multiple version of drivers to develop applications with different driver versions.
This problem happens to our partners.
Example:
I have a customer that want to uses LabVIEW 2014 and another one that uses LabVIEW 2017. So I would like to make a project with 2014's dependencies and another project with 2017's dependencies.
So the idea is to manage the dependencies in the project itself.
Antoine
The operating system takes a long time to open an application when you need to open many file, if we group files in larger files, the times are reduced. With LabVIEW we can create libraries ".llb" is a really funky zipfile, but it is a file that was introduced to provide functionality in the past.
Like Java uses the ".jar" to create packages and distribute the code more easily. They are built on the ZIP format and typically have a ".jar" file extension; LabVIEW uses the ".vip" to create packages with VIPM. VI Packages are similar to zip files in that they contain all the VIs and resources for a specific LabVIEW add-on. But ".vip", are not recognized by LabVIEW in the project tree, instead ".llb" files, we can access its contents from the project tree of LabVIEW.
From a labview project, we can build a ".zip" file. (Build Specifications>New>Zip File). But if we enclose the project in the .zip file, it does not show us the content tree.
My proposal is that LabVIEW can recognize the contents of the ".zip" files, as well as the ".vip", to be able to access its contents and be able to use the lvlib, lvlibp, class, vi ... that are contained. In this way, we can use ".vip" files in <vilib> \ *, <urllib> \ * ... and be able to use its contents without needing to unzip it.
It would be nice to improve documentation created by Tools->Import->Web Service... wizard.
Especially, I suggest to automatically create Description in created .lvlib Documentation so that it would be immediately clear which WSDL URL is handled by that library. Currently, WSDL URL is only placed as a String constant in Open Web Service.vi which is not really convenient.
Thanks for understanding and support.
My tools are technical facing, and I use math.  Instead of ASCII only, a "markdown friendly" version of MathJax, something that allowed me to write clean equations, would be useful.
instead of writing
     "sin(x^2) e1 +cosh(1/x) e2"
I could enter the text
 "$sin\left(x^2\right)\hat{e}_1 + \cosh \left(\frac{1}{x} \right ) \hat{e}_2$"
which is LaTeX in a wrapper
And I would see displayed this:
LaTeX is deep and wide, developed for decades, nicely licensed, and supported well in academia.
Some linkes:
