Community Browser
Top Authors
Post an idea
I wouldn't call it common knowledge, but it's certainly not unknown that there are LabVIEW callback VIs that are invoked if present when certain development environment events happen. With the growing prominance of scripting and the increasing ability to develop custom tools to inhance development, I suggest a more flexible approach to these callbacks. Right now, if you want to use these VIs you have to be careful that you don't overwrite the existing VI (if there is one), or you have to manually go into the VI and drop your subVI that you want to run, within the specific callback VI. It would be nice if there was some tool within LabVIEW that allowed you to select the VIs you would like to run on certain LV Development Environment events, and then the paths to those VIs would be fed into the callback function VI to be called dynamically. While us developers could create something like this on our own, a standardized template for a more flexible callback would be nice. This would ensure the developer could create VIs to, say, run on LabVIEW startup but never have to muck with the actual lv_init.vi VI, worry about what's already in the VI and overwriting it, etc. They would just have to configure another path to a VI for the lv_init VI to call. If anyone has a more flexible idea, please feel free to add to this.
My customer is using LabVIEW 2009 with SIT, MATLAB R2007B and he was able to transfer more than 97 elements of array data with his Simulink .mdl file with the following configuration:
- Configuration parameter of MATLAB model: solve complete time: inf, type: fixed step, solver: discrete, fixed step sample time: 0.01
- Default LabVIEW array reading rate defined by auto generated VI: 50ms >> changed to 5ms
- Executed in Windows local host
However, when the .mdl file is converted to DLL, it seems as though that an array size of over 97 cannot be transferred.
The issue seems to be able to be produced even with multiple arrays or multiple scalar controls so I believe it seems to be an issue of how much data it can handle and not a data type issue. As I mentioned previously, data is able to be passed up till a certain amount but after this "threshold", data does not seem to be passed and the default value of 0 is displayed on the indicator. (In an array, the specific array size is initialized but after the threshold, 0s are shown)
I was also able to reproduce the issue on my end with the attached files.
There are methods available to covert from .sif files commonly used with InField to .tdm or .tdms but not the other way around.  It has been suggested by customers to provide a method for this conversion.
Hello, community
Since some years I'm using LabVIEW now (currently 2010). I'm working in the automation business branch and I see, that there are many HMI visualization softwares around. Nearly all of then support the inclusion of ActiveX plugins into the HMI surface. We are using LabVIEW, among other software, to control our machines. The HMI software we have to use is normally decided by our customers, so not always the same HMI software. Mostly we use Wonderware-InTouch or Siemens-WinCC. Using LabVIEW as HMI host system is not an option, as customers want to stick to their favorite tools and want to be able to manipulate the HMI by themselves. We would like to replace certain parts of our HMI by LabVIEW-VIs.
This can currently be done by
  • Compiling the VIs we want to display as standalone programs with HTML server included.
  • Installing a runtime LV on the HMI-PC (Windows based)
  • Running the VIs
  • Including a WindowsExplorer.ocx into the HMI project and displaying the VIs via Web connection.
This is very sub-optimal because it includes many superfluous things and induces a more than necessary amount of problem-sources.
What I would like to be able to directly build an .ocx file out of our VIs and so include our VIs directly as AvtiveX objects into the HMI (instead of Windows Explorer as wrap around).
What do you thing about an application builder able to produce ".ocx" output?
Ralf
I really like the changes to the Create Data Member Accessor Screen in LV2009 (and LV2010).
I like the Place new accessors in this folder logic.
One thing that would be cool to extend on it would be if the screen allows you to set the scope of a new Virtual Folder at the same time.
21684iC82E6A87291349BB
This would save time as you would not have to right click and set the scope of the new Virtual Folder from the Project Window the first time it the Virtual Folder is created.
If the Virtual Folder already exists in the Class then this option should be grayed out and disabled.
The current implementation of the integrated SCC options have an option to exclude (or ignore) vi.lib and instr.lib files.
Mysterically user.lib cannot be excluded!
This ought to be fixed.
Ton
I work as a LabVIEW integrator and for one of my customer I develop application, with maintenance goal for their installation all over the world with RS232 or Bluetooth communication for example, deployed on targets as PDA (PocketPC 2003 & Windows Mobile 6) or Touch Panel (Windows CE 4.2 to 5.0) using LabVIEW 8.6 Mobile Module.
This LabVIEW additonal module works quite well to deploy the same application in this differant targets, but I encountered some problems and I have some suggestions for Mobile Module :
1/ MMI (Man Machine Interface)
      -  for graphics indicators (as Gauge or Slide) graphical object ramp or multi Slider is deleted by LabVIEW when you build an EXE => I think that a graphical objets with all its graphical property could be added in Mobile Module (and works on these all targets). See examples in GraphicalObjects.PNG
      - as I say in my introduction my application is deployed all over the world and usually I used "Caption" dynamic modification for multilingual management for all my controls & indicators. But in mobile module we can't do this (but we can modify dynamically boolean text), so I think that it could be possible.
2/ VISA (& Bluetooth) Management
      -  I think there is a bug with VISA installation. Indeed with the installer you can choose the installation directory (default directory or specific directory : in non volatil memory) but if you don't install VISA support in default directory it doesn't work (with PocketPC 2003 for example) I think that could be resolved
-  As I said in introduction my application could communicate throught different protocols (RS232, Bluetooth) and with LV 8.6 Mobile Module we can now use VISA : great !!!. But in Windows Mobile 6, VISA does not support bluetooth (it seems to have an incompatibility with virtual aliases in the registry) ; and in PocketPC2003 it works very well. I think that could be resolved
Problem
I would like to create HTML report of my unit tests run together with information about project code coverage. This can be achieved if the "Generate HTML report" option is checked in Project>>Properties>>Unit Test Framework and when the tests are run via toolbar operation "Run Unit Tests". However, I want to create same HTML report with PROJECT CODE COVERAGE programmatically via "Create Report.VI" or CLI, but the report generated in this way doesn't contain the code coverage information.
Run via Create Report.vi
Run via toolbar
Why This Matters
This functionality can be useful for running unit tests and report creating via custom CLI operation for CI. My scenario is to use the report as an CI artifact with informative value about code coverage.
It would be nice to have a managed solution to get LV Class properties both in development and in runtime environment: name of the properties, concerning accessor VIs with path and scope information.
Currently the only way to get these information is to handle the classes by XML parsing methods. This is neither managed solution nor working for classes which are found in compiled codes.
Let's Encrypt is an Certificate Authority (CA) that provides FREE TLS certificates for people and organisations to secure their websites and servers. Their certificates are valid for a maximum of 3 months, but client applications can automatically update the certificate when due.
It would be very nice to have this functionality in the NI web server. Exipiring certificates are cumbersome to manage.
Actually the LabVIEW project Build Specification allow to create an old style DLL shared Library.
This kind of DLL is not so user friendly to use, because you have to define the DLL function prototypes, when you want to use them  ...  (Import, declare ... )
It would be nice, to be able to create a .Net DLL shared Library which is more easy to interface. (Without declare, import ...)
The DotNet DLLs can be used without having to create Import declaration.
The self documentation of DotNet DLLs don't need to declare all function prototypes when you want to use them.
My need is :
- To create LabVIEW drivers libraries
- To create Packed libraries, from these librairies, to be used by LabVIEW projects or TestStand sequences.
- To create DLL from the same libraries, to be used by dotNet projects
Thanks a lot for reading.
Manu.Net
Usually, unsupported LabVIEW features can be enabled with nothing more than an undocumented INI key. The one exception that I know of is the integrated XNode development feature in the Windows version, which is instead controlled by the license manager. (This feature exists in the Linux and Mac versions as well, but on those versions it's an INI key like everything else.)
Despite not being officially supported, community-made XNodes are very much a thing. Even on the Windows version, one can still create them using a third-party editor, or hack their way into the built-in one somehow. And it's clear that NI (rightfully) doesn't put much if any continued effort into preventing third parties from making XNodes, as the same methods that were used over a decade ago still work just as well now.
I'm not asking NI to provide official support for XNodes necessarily, but I think it's for the best if they at least remove all unnecessary, artificial roadblocks, and open up the XNode development forum and perhaps some internal documentation to the public, so community-based developers can at least have the best shot at learning how to do it right. You've already done this with Project Providers; why not XNodes as well?
if only LabVIEW can read and write PDF files, since it is already an open format. needless to say for the function of writing in report generation, but reading from PDF can also provide: text, picture or even CAD data that can then be used from automated mass data entry, QC vision inspection (CAD vs fabricated), augmented reality visualization of measurements (temperature, stress, vibration, etc) and much more...
if only...
If we can have instrument simulator VIs, we can test our codes prior to the actual hardware acquisition
The idea proposes device driver packages from IDNet to include a vendor instrument simulator VI that can be run prior to code testing. The VI can be configurable (VISA based on virtual ports created during runtime, file paths to read from to simulate measurements and responses to messages, etc) and started asynchronously (call & forget) at the start of the program and terminates when the caller terminates.
or as a template from the "New > Simulated Instrument" where user can modify according to the instrument that they are going to use.
...and that it covers NI and 3rd party instruments
LabVIEW AF is a fantastic tool to create multi-threaded messaging applications the right way. It promotes best practices and help write big yet scalable applications.
I feel however that there is not enough included in the box 🙂 When looking at many other industry implementation of the actor model e.g. Scala Akka, Erlang, Elixir, microservices in many languages etc. you find that the frameworks usually include many more features. https://getakka.net/
I understand the decisions behind the design for AF yet would like to start a discussion about some of these.
I would like to see the following features being included into AF:
1. Ability to Get Actor Enqueuer by Path through hierarchy of actors e.g. /root/pactor/chactor could be used to get the enqueuer to chactor. This would probably require actors to have unique paths pointing to them. Having a system manager keeping all enqueuers on local system is not a bad thing. It is a good thing.
2. Ability to seamlessly communicate over the network and create your own queue specifications. For example actors should be able to talk between physical systems. Using the Network Actor is not a good solution, because it is simply to verbose and difficult to understand. The philosophy of AKKA should be embraced here "This effort has been undertaken to ensure that all functions are available equally when running within a single process or on a cluster of hundreds of machines. The key for enabling this is to go from remote to local by way of optimization instead of trying to go from local to remote by way of generalization. See this classic paper for a detailed discussion on why the second approach is bound to fail."
3. Improved debugging features like MGI Monitored Actor being inbuilt. https://www.mooregoodideas.com/actor-framework/monitored-actor/monitored-actor-2-0/
4. Included Subscriber Publisher communication scheme as a standard way for communicating outside the tree hierarchy. https://forums.ni.com/t5/Actor-Framework-Documents/Event-Source-Actor-Package/ta-p/3538542?profile.language=en&fbclid=IwAR3ajPR1lvFDyPFP_aRqFZzxR4FCQXh2nB2z0LYmPRQlnvXnsC_GQaWuZQk
5. Certain templates, standard actors, HALs, MALs should be part of the framework e.g. TDMS Logger Actor, DAQmx Actor. Right now the framework feels naked when you start with it, and substantial effort is required to prepare it for real application development. The fact that standard solutions would not be perfect for everyone should not prevent us from providing them, because still 80% of programmers will benefit.
6. Interface based messaging. The need to create messages for all communication is a major decrease in productivity and speed of actor programming. It also decreases readability. It is a better with the BD Preview in Choose Implementation Dialog in LV19, but still 🙂
7. This is more of an object orientation thing rather than actor thing but would have huge implications for actor core VI, or Receive Message VI. Please add pattern matching into OO LV. It could look like a case structure adapting to a class hierarchy on case selector and doing the type casting to the specific class inside the case structure. You could have dynamic, class based behavior without creating dynamic dispatch VIs, and you would still keep everything type safe. https://docs.scala-lang.org/tour/pattern-matching.html
The natural way for programming languages to evolve is to take ideas from the community and build them into the language. This needs to also become the LabVIEW way. I saw a demo of features of LV20 and I am really happy to see that many new features were inspired by the community. Lets take some ideas about actor and add them in.
I wanted to share my view on the direction I think AF should go. I see in it the potential to become the standard way to do big applications, but for that we need to minimize the barrier to entry.
TDMS files generally come in pairs.  There is the TDMS file itself which contains all the data and meta data stored in the file.  And there is usually a tdms_index file.  This is the file with the meta data in it, but not the actual data.  The idea being that this index file is created from the original file, but since it doesn't contain all the extra data, it is faster to search through for a particular offset in the file to find something.
If a TDMS file exists in a folder without a tdms_index file, it will generally be created when calling the TDMS Open function.  This means when DIAdem indexes it, or when Excel Importer opens it, or when Scout opens it, this index file is created.  Often a useful way of looking at a folder of logs is to look at the Date Modified or Date Created and look at the newest.  But if we are viewing a folder of TDMS files which don't have the indexes, as soon as we open one to view it, the index file will be created with the modified and creation date being set to right now.  This suggestion is to have it be set to the same value as the original TDMS file.  As always pictures are useful.  Here is a folder of TDMS files sorted by the date modified.
After double clicking that file the TDMS editor of choice opens it and the directory looks like this:
The index file is created, but since it has a newer mod date it moves to the top of the list.  My suggestion is to have the index file have the creation and mod date set to the TDMS file so the directory will look like this after it is created:
Yes I realize you can write code to set this but I can't think of a reason why I would ever want to know what the date and time that the index file was created.  I'm only interested in the data, not the index file.  If this is implemented on the TDMS API side of things, then all tools that get made from that point forward will have the file modification set automatically.
From LabVIEW Project, we can access the last modified files, from the menu File>Recent Files.
When we work with a large amount of files, it is very useful, so as not to have to navigate the whole tree, to find the last modifies files.
But not always we will want to access the recently modifies files, so I propose to create a quick access category in the project tree.
When we work on a project with a large number of library, class, vi,... it can be difficult to find the files that need to be modified, so it can be very useful to have quick access to those files that the developer considers.
Formula node is a great tool for evaluating mathematical formulas and expressions. However right now, you can one time input text into the formula node (during application development) and after compilation, the node does only this one added text and any change would mean a recompilation of the code. It would be absolutely fantastic to dynamically load the node text for example from some file…the node would then have not only a variable input, but also one text input, and the text would bet the formula node text.
It would then be a upgraded sort of a „eval formula node.vi“, which would accept also syntax for while loops, for loops and all the other stuff and not only a regular expression.
Easy printing the test reports with the Front panel as per the A4 Standard.
For making the A4 Standard printing needs the option to make Pane A4 Size.
Then we can make easily create the front panel reports easy manner, add Indicator (result ,title, logo, auto signatures etc)  in the report and generate the print out.
