Community Browser
Post an idea
With the advent of scripting, it is possible to create some nifty tools to aid in code writing.  Those that work on individual elements of the FP or BD can often work nicely in Quick Drop or the Right-Click Framework.  Some of these tools however, work most naturally as an addition to to Tools menu.  The missing piece of the puzzle for seamless integration into the IDE is the ability to customize keyboard shortcuts for those additions.  I would simply like the ability to assign keyboard shortcuts to any item which appears in the Tools menu.  I have at least three things in there already more worthy of Ctrl-t.
As described in the following "Darren's Weekly Nugget" posting, LabVIEW provides an API for programatically building projects. Especially when dealing with large projects, this can be a real time saver and great technique for quality control (ensuring that the build process is carried out the same way each time). However, when doing a programatic build, there is no status information - the LabVIEW application that calls these APIs is just left, giving the impression that it has locked up. This can be especially concerning given that builds of complex applications can take quite a while.
A solution seems pretty straight forward - give the build API calls, the option to display the standard building dialog.
A simple boolean value could allow an API user to provide some feedback to the hosted application as to what is going on without any of the complexities of other status feedback mechanisms (although *any* mechanism would be better than none!)
Weekly Nugget Posting regarding App Builder API: http://forums.ni.com/t5/LabVIEW/Darren-s-Weekly-Nugget-02-15-2010/m-p/1072575
I did a search on this forum to see if the subject been asked before but couldn't find it quickly, so I post. I have been seeing business push and pressure to move in this direction over the years, more so recently and have migrated to eclipse for my current project and like CDT. I saw the following today and it got me off my inertia to ask/feel the question here. I would venture that Operating systems and other mature s/w tools aren't rocket science anymore, but commodities and open-source w/ customization makes sense. Easier said that done. Thoughts?
pavan
This inspired me to ask the question:  The Eclipse Helios simultaneous release of 39 Eclipse projects and 33 million lines of code showcases the diversity and innovation going on inside the Eclipse ecosystem. In terms of statistics, the Helios release includes 33 million lines of code developed by about 500 Eclipse.org committers from 44 companies. The important thing to remember about Helios and Eclipse simultaneous releases in general is that even though it's a simultaneous release, it doesn't mean these projects are unified. Each project is a separate open source project within Eclipse.org, operating with its own project leadership, its own committers and its own development plan. The simultaneous-release concept is designed to provide a transparent and predictable development cycle.
Other ref:
Microsoft ups the ante in the robotics market, makes MSRDS free ... (see coments from emiliekopp)
CentOS, Ubuntu...
Eclipse & addons
Python
GCC
Octave
Scilab
Android (I think it is open?)
Open-office
ISO formats for docs
Open Car
Open prosthetics
The list goes on.
I'd like to see something like a conditional disable structure that would be sensitive to fields in an .ini file at runtime, not compile time.
My problem is that I have an application that can access many different third party cameras. For this application to work every VI that accesses a camera specific .dll function must have assess to that .dll or I get a broken VI. When I compile the VI I have access to these .dlls but when I build an application.exe and distribute it I only want to distribute the .dlls for one of the cameras. If I could distribute a .ini file with the application.exe that indicated which camera the drivers were installed for then the application would disable the code for all the other cameras and the VI would not break.
Thank you,
Chuck Lippmeier
Using the LabVIEW 2009 Build Spec (as an example) allows you to add a Destination to a Library which is very handy, as it means you can namespace VIs at build-time.
I would like to take this a step forward and then be able to set that new Library as a Sub-Library of another Library that already exists in the Project.
I would then want to be able to set the scope of this Sub-Library as well (relative to its now, Parent).
This combined with my Locking State Idea would allow be create a Distribution that would hide and protect a Support VI Library
As the Sub-Library would be Private Scoped (from above) and the Parent Library would be set Locked (does not show Private Members).
I currently can implement this using Scripting but it would be nice to have it native.
Cheers
-JG
17619iFB1C3A1375DBE39317621i6935DFDFCA489040
Locking a library during an automated build seems like a very natural thing to do.  Would be nice to be able to script it.
This may not technically be a standard LabVIEW Idea, but it is an idea nonetheless and there is no where else to post this idea in the Idea Exchange Forum and I want get other peoples feedback.
I would like to suggest that sending packages (.ogp, .vip, .vipc files) to NI Support is an acceptable way to submit code for reasons relating to code (support, issues, review help, CARs).
I have had problems sending code and then sending all dependencies as well, along with instructions on where to install etc... (for example here) that was solved once I was able to convince my support AE to install VIPM. It also saved me a lot of time (other I had to rebuild code in order to send it as well etc...)
(IMHO) I think this Idea would compliment NI moves towards establishing it's LabVIEW Compatibility Program (which I am assuming VIPM and OpenG will be covered under)
Additionally there seems to be great acceptance by NI to packages already whereby I have seen NI code in documents/white-papers posted as packages.
Thanks to Christian L and Laura F these files types are now compatible with the new NI Forums.
Here are some of my notes on this Idea:
  • VIPM Community Edition would have to be installed internally (but it is free so there would be no cost)
  • I am not looking for NI to support VIPM itself (unless it is covered under the Product Partner Program?) only that I can send a package to NI Support and they will know what to do with it and be able to install it
  • OpenG would also be required to be installed as well (after all it is the LabVIEW main/only? Open Source movement) (this is free too).
  • That way I would not have to send large dependencies files (only include my internal package), and then email size would not normally be an issue (although I have used NIs FTP successfully in the past due to large files) but email is nicer.
  • All this would lead to a more streamlined approach to Support for those developers who rely on packages
Please post your feedback.
Cheers
-JG
I would like to expose the "Replace With..." method in the LabVIEW Project Right Click Popup menu via VI Server/Scripting.
This would allow e.g. a developer to update the LabVIEW Project after a SCC Rename transaction and preserve all linking.
Currently this is unavailable.
17225iD565D229419523A1
In fact I would like a lot more exposed, see here, but Antoine and I agree this was more important and may have more chance of happening quicker?
Current methods for the LabVIEW Project that exist as Right Click Popup Menus are not exposed via VI Server/Scripting.
However, these methods would be very handy to call programmatically.
I say, if we can Right Click Popup on it, then we should be able to script it!
I have LabVIEW Classes of the same name in two separate LabVIEW Project Libraries (e.g. for namespacing reasons) in the same LabVIEW Project.
When I go to configure the Inheritance of the a Class, the All Class In Project list just shows the Class names.
These names can be the same and it is not immediately obvious which Class is the correct one.
The only way to pick the correct Class is by looking at the Selected Class Path on the right.
My idea is that the All Class In Project list will display the qualified names.
Either as one long name or nested, mimicking the LabVIEW Project hierarchy.
(I think I currently prefer nested).
Create a VI to read the config from string instead from a file for in memory configuration.
Also create a VI to read out the config as string.
Regards
Marc
Create a VI, which allows to get the config file path from the config reference.
Marc
in LV2009 a new set of VIs have been published for working with configuration VIs. They are now part of config.lvlib. But some VIs of config.lvlib are marked private, therefore I cannot use these VIs as Sub-VIs, if the calling VI is not part of config.lvlib. This is bad (at least for me), since I have written some tools to load a configuration directly from a string and not from a file. To do this in LV2009, I need these private VIs, which I cannot use without changing config.lvlib.
Therefore I suggest to make all VIs of config.lvlib public. In fact, is there a good reason, why these are private in the first place?
Marc
A native Icon Editor API seems a natural evolution for interacting with the new icon layers that appeared in LabVIEW 2009.
The current API is the only way (I know of) to interact programmatically with the Icon Layers.
This is a very handy API that should be polished up and included with LabVIEW.
You can download the current version here:http://decibel.ni.com/content/docs/DOC-8647
  • I like to make plugin tools that work on items in the project e.g. Libraries/Classes.
  • I like implementing these plugins using the Quick Drop plugin framework.
  • And I normally always work with the LabVIEW Project in my standard workflow.
If I want to act on a Library, obviously I can just open a Member VI and get a reference to the Parent Library to do this.
However, I feel it would be more natural to Quick Drop on the Library in the Project itself!!
I also feel that it would be faster...
...And isn't that what Quick Drop was invented for?
I don't know if native options would ever exist, I am looking to call my own shortcuts - but there is alot of scope to implement custom plugins.
I have only given one example above.
Cheers
-JG
Currently when binding a .Net Constructor node to a private assembly the vi saves the absolute path to the assembly.  This behavior causes a lot of pain when multiple developers working on the same project have the source code repository mapped to different local directories.  Every time I load a project I go through several iterations of Labview/.Net searching for the "missing" assemblies.  Depending on what I have on my disk at the moment, oftentimes it will bind to a dll that's in a completely different project.** Trying to find a workaround for those vendors who refuse to put their assemblies in the GAC has been problematic.
Note I'm not asking for a path input to the .Net Constructor node.  I just want the option for the path to be stored internally as a relative path rather than an absolute path.
**This is a little odd given private assemblies aren't supposed to be loadable outside of the given .Net AppDomain.  I guess there's not a 1:1 correlation between Labview app domain and .Net AppDomain?
Firefox is not publishing the PNG data that contains a snippet inside the Drag and Drop info, however the info is stored inside CFSTR_FILEDESCRIPTOR (source) it would be very helpfull if LabVIEW supported this as well.
TOn
Now that .NET 4 is out and people are using it to program, LabVIEW should support the .NET 4 framework. LabVIEW needs to stay on top of the game and make it easy to use all the latest technology. Especially something as widely adopted as .NET.
Currently, no version of LabVIEW (released or in Beta) supports .NET 4.
