Community Browser
Post an idea
If we can have instrument simulator VIs, we can test our codes prior to the actual hardware acquisition
The idea proposes device driver packages from IDNet to include a vendor instrument simulator VI that can be run prior to code testing. The VI can be configurable (VISA based on virtual ports created during runtime, file paths to read from to simulate measurements and responses to messages, etc) and started asynchronously (call & forget) at the start of the program and terminates when the caller terminates.
or as a template from the "New > Simulated Instrument" where user can modify according to the instrument that they are going to use.
...and that it covers NI and 3rd party instruments
In Enthought's python integration toolkit (PITL), the "Open python session" VI accepted as an input the path to the python.exe file to use for the python kernel. In LV2019  the "Open python session" accepts a string "2.7" or "3.6", and then labview searches the system path to find the python installation.  The LV2019 method is vastly inferior to the PITL method. Due to the way the LV python node requires one to manipulate the system path in order to find the desired python installation, I realized that this is a complete non-starter for sending compiled applications to end users, because the end user may have multiple python installations on their computer, and I can’t expect them to bend over backwards just to be able to use my compiled LV app.
I do not know how NXG currently handles this, but I hope that they emulate the PITL method. Furthermore, it would be great if NXG could handle arbitrary python distribution, such as Anaconda, rather than just the bare bones installation from python.org. It would also be great if there was more documentation about the python node in general--there is very little to be found currently. The Labview python node is shrouded in mystery (e.g. what the heck is NIPythonInterface.exe) whereas the PITL was very self-explanatory. It is a shame that NI displaced such a useful product and replaced it with an inferior one.
NXG needs an Idea Exchange.  The feedback button is a lame excuse for a replacement.  Why?
  • I can't tell if my idea has been suggested before.  (And maybe someone else's suggestion is BETTER and I want to sign onto it, instead.)
  • NI has to slog through bunches of similar feedback submissions to determine whether or not they are the same thing.
  • Many ideas start out as unfocused concepts that are honed razor sharp by the community.
  • This is an open loop feedback system.
Let's make an Idea Exchange for NXG!
Perhaps a future LabVIEW version can include NI-defined common interfaces (with ~1 method each).
Examples might include "Initialize", or "Dispose" (to borrow from C#). "Shutdown" might be another option.
This could allow different developers to all base their code on a set of common shared interfaces, and then users receiving their code (via VIPM, GCentral, etc etc) could use it as a plugin more easily.
I am happy that LabVIEW supports Python code with the Python Nodes. But it is difficult to debug errors. A console showing the output of the Python Scripts would be handy.
Enthought's Python Integration Toolkit had this function so I guess it shouldn't be a big thing to add?
The Property class, which represents the property node, has a property called All Supported Properties which ideally would show all the properties supported by the class the property node is linked to.
The problem is that it doesn't. If you have nested properties which come from another class (for example, the properties for the caption which can be selected by opening the pull right menu, as seen in the top image), those properties aren't returned when you call the property, and instead you just get the property for the caption reference, as seen in the bottom image, where the ControlIndex property is shown immediately after the Caption property.
Instead, I want either this property or a new property to return all of the nested properties as well, just like you get in the UI.
This would be useful for setting properties using scripting and alternate UIs (like this one or this one, which can't work today, because they can't get the full list of properties).
Hello all!
The standard LabVIEW plugins are great but operate based on Ctrl + Key shortcut. This means that after a while almost all of your keybord keys can be occupied by a shortcut.
Please add an interface for defining commands in the QD ComboBox, which could be used as a more extensible option over single keys.
Example - a Dialog command could be invoked like this:
Ctrl+Space -> Dialog Text -> Ctrl + CCtrl+Space -> Dialog Text -> Ctrl + C
Example community package implementing this can be found here: https://forums.ni.com/t5/Quick-Drop-Enthusiasts/Class-QD-Plugin-Package/gpm-p/3992772
Thank you!
The current implementation of flattening and unflattening from XML is quite noisy and includes information unnecessary for the users. Rewriting it or including Pretty Print functionality to LabVIEW would greatly simplify loading settings, exchange of data with other languages, dynamic configurations, visualizations of complex systems, network communication etc.
For community solution and examples of these features please go to -> https://forums.ni.com/t5/LabVIEW-APIs-Discussions/Tree-Map/td-p/3972244
This could include also Pretty JSON since XML and JSON are interchangeable -> http://www.utilities-online.info/xmltojson/#.Xc6XjVdKiUk
Additionally the XML parsing should be implemented without requiring Windows .NET platform components, so it can be done on a real-time system. Current XML parsing functions cannot be called on RT.
LabVIEW AF is a fantastic tool to create multi-threaded messaging applications the right way. It promotes best practices and help write big yet scalable applications.
I feel however that there is not enough included in the box 🙂 When looking at many other industry implementation of the actor model e.g. Scala Akka, Erlang, Elixir, microservices in many languages etc. you find that the frameworks usually include many more features. https://getakka.net/
I understand the decisions behind the design for AF yet would like to start a discussion about some of these.
I would like to see the following features being included into AF:
1. Ability to Get Actor Enqueuer by Path through hierarchy of actors e.g. /root/pactor/chactor could be used to get the enqueuer to chactor. This would probably require actors to have unique paths pointing to them. Having a system manager keeping all enqueuers on local system is not a bad thing. It is a good thing.
2. Ability to seamlessly communicate over the network and create your own queue specifications. For example actors should be able to talk between physical systems. Using the Network Actor is not a good solution, because it is simply to verbose and difficult to understand. The philosophy of AKKA should be embraced here "This effort has been undertaken to ensure that all functions are available equally when running within a single process or on a cluster of hundreds of machines. The key for enabling this is to go from remote to local by way of optimization instead of trying to go from local to remote by way of generalization. See this classic paper for a detailed discussion on why the second approach is bound to fail."
3. Improved debugging features like MGI Monitored Actor being inbuilt. https://www.mooregoodideas.com/actor-framework/monitored-actor/monitored-actor-2-0/
4. Included Subscriber Publisher communication scheme as a standard way for communicating outside the tree hierarchy. https://forums.ni.com/t5/Actor-Framework-Documents/Event-Source-Actor-Package/ta-p/3538542?profile.language=en&fbclid=IwAR3ajPR1lvFDyPFP_aRqFZzxR4FCQXh2nB2z0LYmPRQlnvXnsC_GQaWuZQk
5. Certain templates, standard actors, HALs, MALs should be part of the framework e.g. TDMS Logger Actor, DAQmx Actor. Right now the framework feels naked when you start with it, and substantial effort is required to prepare it for real application development. The fact that standard solutions would not be perfect for everyone should not prevent us from providing them, because still 80% of programmers will benefit.
6. Interface based messaging. The need to create messages for all communication is a major decrease in productivity and speed of actor programming. It also decreases readability. It is a better with the BD Preview in Choose Implementation Dialog in LV19, but still 🙂
7. This is more of an object orientation thing rather than actor thing but would have huge implications for actor core VI, or Receive Message VI. Please add pattern matching into OO LV. It could look like a case structure adapting to a class hierarchy on case selector and doing the type casting to the specific class inside the case structure. You could have dynamic, class based behavior without creating dynamic dispatch VIs, and you would still keep everything type safe. https://docs.scala-lang.org/tour/pattern-matching.html
The natural way for programming languages to evolve is to take ideas from the community and build them into the language. This needs to also become the LabVIEW way. I saw a demo of features of LV20 and I am really happy to see that many new features were inspired by the community. Lets take some ideas about actor and add them in.
I wanted to share my view on the direction I think AF should go. I see in it the potential to become the standard way to do big applications, but for that we need to minimize the barrier to entry.
It would be helpful to have Refresh Palettes operation as part of the built-in Command Line Operations. This would help fill in the NI Package's short coming of not having palette tools like VI Package Manager. My suggestion is the Operation Name to be RefreshPalettes and require any additional arguments.
It would help to have an option to ignore Bad VIs errors when calling a mass compile via LabVIEWCLI. This makes the CLI MassCompile unusable for deploying code with NI Package Manager that has API Tree VI. It would help to have an option to ignore those errors so that NI Package custom execute could run successfully. I would think it could be defined as optional argument. My suggestion for the argument is -IgnoreBadVIs true|false with a default of false.
I'm working on large AF projects and I want to be able to pack my actors into lvlibps as there are lots of benefits of using PPLs. However, I'm a bit uneasy about distributing the PPLs with the executable because it's possible to reuse the public methods in a PPL. (The software I write is mostly licensable, but it would still be possible for competitor companies to reuse the public APIs)
What I would like is a way of securing/encrypting PPLs when distributing the executable.
I really like using VIMs; however, I have been having a lot of issues when saving for previous versions / VIM based bugs.
What I would like is a right-click (under the advanced tag) to convert VIM to VI copy (which you could then save) and a 'tools>Advanced>replace all VIM instances in the project' tool.
I attempted to make this myself, but it turns out the 'Replace' scripting method doesn't work with VIMs and I don't really want to go down the route of deleting, placing, rewiring.
So either, could I suggest creating the tool, or providing the scripting functions for us to create the tool.
NB: This is the proof of concept I was trying out to change VIMs to VIs:
Order of operation:
  1. Get a reference to SubVIs and filter for VIMs
  2. Create a copy of the VIM and save as a VI
  3. Replace VIM with new VI
TDMS files generally come in pairs.  There is the TDMS file itself which contains all the data and meta data stored in the file.  And there is usually a tdms_index file.  This is the file with the meta data in it, but not the actual data.  The idea being that this index file is created from the original file, but since it doesn't contain all the extra data, it is faster to search through for a particular offset in the file to find something.
If a TDMS file exists in a folder without a tdms_index file, it will generally be created when calling the TDMS Open function.  This means when DIAdem indexes it, or when Excel Importer opens it, or when Scout opens it, this index file is created.  Often a useful way of looking at a folder of logs is to look at the Date Modified or Date Created and look at the newest.  But if we are viewing a folder of TDMS files which don't have the indexes, as soon as we open one to view it, the index file will be created with the modified and creation date being set to right now.  This suggestion is to have it be set to the same value as the original TDMS file.  As always pictures are useful.  Here is a folder of TDMS files sorted by the date modified.
After double clicking that file the TDMS editor of choice opens it and the directory looks like this:
The index file is created, but since it has a newer mod date it moves to the top of the list.  My suggestion is to have the index file have the creation and mod date set to the TDMS file so the directory will look like this after it is created:
Yes I realize you can write code to set this but I can't think of a reason why I would ever want to know what the date and time that the index file was created.  I'm only interested in the data, not the index file.  If this is implemented on the TDMS API side of things, then all tools that get made from that point forward will have the file modification set automatically.
If I create abstract messages for the calling actor, I often have to write a wrapper function so the child classes can use the abstract message.
This is a repetitive task that would be a prime candidate for scripting. Images below is an example of the type of wrapper I'm referring to.
Send Abstract Message WrapperSend Abstract Message Wrapper
DVRs are references, and are automatically released when the VI hierarchy that created and "owns" it goes idle (stops executing).  Commonly, the DVR just contains by-value objects, or LabVIEW references that are also automatically released, but an important use case of DVRs is wrapping a non-labview reference that must be properly cleaned-up.   An example is an SQLite Connection pointer that must have a dll method called on it in order to release the database file it is holding open.  Many dlls have similar pointers/handles that need to be properly closed.  This is a headache for Programmers, who cannot rely on a stopped VI releasing its resources, often requiring restarts of LabVIEW to unload the dll.
A clean and easy solution to this problem would be to allow a "DVR Cleanup Callback VI" to be registered with the system when the DVR is created.   That VI would be called if and only if the DVR is release because its calling VI hierarchy goes idle.   This VI would contain the code to cleanup/close the contained non-LabVIEW references.  Could have other uses, such as debugging.
I have developed multiple APIs that wrap non-LabVIEW dlls, and this feature would be a very significant help.   Please consider it.
it would be great if adobe reader was built into the additional installers section of the project installer build.
i would think this would be a common thing users end up installing sperately
This is something that started as a way to get data back from Actors in non-actor code (for example, web services). I've never cared for the blocking nature of Reply Msgs and the only other built-in option for getting back data is to make everything an Actor, which is not always an option. Promises solve both of those issues.
The basic idea is an enforced single-writer, many-reader cross thread datatype. In the current implementation, they are not much more than a locked-down, single element queue but you can actually do some pretty cool stuff with just that.
In the message sender, we create the promise and return it. The idea here is that the Actor owns the promise and will fulfill it. This gives us very low coupling for free.
Actor_Example_lvlib_Start_Long_Running_Process_Msg_lvclass_Send_Start_Long_Running_Processd.png
Wait on Promise will wait for the Promise to be fulfilled. It is a malleable VI so that a Default Value (for timeout) and Type can be wired. Using the timeout lets us do other things while waiting for data.
Inside the Actor, we can set the value with Fulfill Promise. Remember, once the Promise is set, that's it, no changing it again. In fact, Fulfill Promise will error out if called twice on the same promise.
Something else really cool we can do is fulfill a promise with another promise. This may seem pedantic at first but it can help keep your code cohesive by passing the responsibility of fulfilling a Promise to another process. For example, if you have a message broker that just forwards a message, you can have the message broker fulfill it's promise to the caller with a promise from the callee.
We can also reject a promise with an error message that will be returned by any Wait on Promise that tries to read it. Rejecting a promise does fulfill the promise so you still cannot set the value later and you cannot reject a promise again.
Finally, we have Destroy Promise. It does exactly what it says on the tin.
I'd love to hit some more of the design points from https://promisesaplus.com/ (mainly adding Then callbacks) but I figure it's at a pretty good spot to share and get some feedback. I'd also like to try to figure out network communication at some point but that's probably a ways away (without some help anyway Smiley Wink).
I'm hosting the code at https://github.com/kgullion/LabVIEW-Promise if you are interested in checking it out or contributing!
Motivation: in my recent project I have got a request from the end user that it would be nice to store configuration data in the same TDMS file where we store measurement results. Of course, we can create this feature programmatically, like we parse through the typdef cluster, using label names and different data types, we can create a kind of API for a TDMS Cluster read/write. However, it is difficult to make it generic, and this is an extra work anyway.
So it would be nice to save my complex Typdef cluster into TDMS, where I store measurement results in a user readable manner (via the Excel plugin) inside different groups and channels. The stored configuration cluster does NOT need to be user readable!
Since TDMS does not have this feature, as a dirty and simple workaround, I will always produce two files during measurement/data processing sequences: a TDMS, and an INI file (via the OpenG Write INI Cluster), then programmatically ZIP them into a single file for data backup (for future reference, it is safer this way).
Would not be nice if we could just write a Typdef cluster to and read from a TDMS file directly?
Like what we can do with the OpenG Read/Write INI Cluster VIs. I understand there is a strong reason why TDMS files limit the data types we can write to them, and it is not allowed to use undefined data sizes, like Variants, strings. Well, we can write strings to TDMS files, but there are some issues/difficulties with this approach if we want to go through a Typedef Cluster->String->TDMS file storing route. Hoovahh had a post about these challenges 2 years ago, where he mentioned he might make it into an Idea, but I could not find it in this forum board, so I make it an Idea: https://forums.ni.com/t5/LabVIEW/Read-Write-Variant-to-TDMS/m-p/3334203
I imagine, NI could implement such feature into TDMS in a similar way, like there would be an "internal part" of the TDMS file where the Cluster is stored as a Variant in binary format. I do not know how the internal things work in a TDMS file, but I imagine such new feature implemented as an extra data type for the TDMS Set Properties would not hurt the speed performance of the Group/Channel level things...?
Idea is quite simple - add to instrument drivers project wizard template for switch/MUX/matrix devices.
Custom switching boards are commonly used, b/c for some simple purposes it is cheaper to make custom design with simple functionality (some micro processor which controls relays), and which could communicate by serial line. Then instrument driver - is ideal solution to create simple API in LabVIEW for its control; but unfortunately, there is no template for such types of devices in New Instrument Driver project wizard.
