Recently LabVIEW has added the following feature: When creating a new wire, double-clicking creates a terminal. This can be an indicator or a control, depending on what was selected. If the wire was started from a data sink (a structure tunnel or a subVI or node input terminal), holding down the Ctrl key while double-clicking creates a constant. This is very useful and saves time. Kudos!
When working with cluster wires, it would be useful if an Unbundle By Name node could be created by:
1. Start creating a new cluster wire or wire branch
2. Hold down a modifier key (Ctrl, Alt, Shift, or a combination thereof) and double-click
Step 1: Start creating a cluster wire
Step 2 - current behaviour: double-clicking creates a terminal. This is useful. Holding modifier keys down (Ctrl, Alt, Shift) does not alter the behaviour.
Step 2 - desired behaviour: Holding modifier key + double-click creates Unbundle By Name node
Notes
- Creating UBN nodes is a common, repetitive action when working with clusters. This gesture would save time.
- The screenshots above show a cluster wire being created starting from a control terminal. The gesture should, of course, work regardless of which object the wire branch was started from (e.g. tunnel, subVI output terminal, etc).
- Perhaps the idea can be expanded to creating Bundle By Name nodes. Perhaps one modifier key (e.g. Ctrl) would create a UBN node, while another key (e.g. Alt) would create a BBN node.
