Community Browser
Top Authors
Post an idea
Currently, on Windows, File:Save As:Rename does not work when changing only the capitalization of a filename. I would prefer that it did. See this discussion for workarounds.
saving with lowercase:
Has no affect on the filename in the finder or in LV.
If a DLL is configured in a Call Library Function Node and is either missing or defective, the entire program cannot be executed. In most situations, this behavior is acceptable.
However, it can also be quite frustrating, especially if the part of the program that uses the DLL is not called. Additionally, it would be helpful for debugging purposes if the program could still execute even when a DLL is unavailable.
Therefore, I propose that the configuration dialog of the Call Library Function Node includes an additional checkbox labeled "Break execution if DLL cannot be loaded." If this checkbox is checked (default setting), the behavior will remain as it currently is. If the checkbox is unchecked, the program should run until the affected node is executed. At that point, the node's error output should indicate either "DLL not found" or "DLL found but cannot be loaded," and execution should proceed beyond the node. In this scenario, it will be the programmer's responsibility to handle the error appropriately.
As an extension of this idea, I could also envision a new entry in the LabVIEW.ini / application.ini file to assist with debugging. If this entry is not present, the explicit configuration of the node will be used. If it is available, it will override the explicit configuration with either true or false.
Please also see this related idea: https://forums.ni.com/t5/LabVIEW-Idea-Exchange/get-DLL-path-from-the-call-library-function-node/idi-p/4433632
Since the call library function node (3) supports wild-cards it is not clear which DLL file is physically used during runtime. Nevertheless this information can be interesting and important in some cases. Currently there is no way to get this information (1). Therefore I suggest to show the DLL-Path-Output always (2). It shall return the entire path and name of the currently loaded DLL.
Suggest adding functionality to the event structure when handling Value Change events, so that the user can tell whether the source of that generated event was via a write to a Val(Sgnl) property node, or via a Front Panel change made by the user.
This could potentially be achieved (albeit with backwards compatibility considerations) by defining an appropriate enum constant for the eventsource.ctl which available in the "Source" field of the Event Data Node (currently has "LabVIEW UI, ActiveX, User Event, and Other <>..." as the only defined constants).
More discussion and rationale is in this community topic:
Solved: Re: UI-Triggered Event vs. Value (Signaling) Event? - NI Community
I want an event to trigger when the user switches from linear to logarithmic mapping for a control.
None of these currently existing events trigger for this scale change
Related forum discussions:
https://forums.ni.com/t5/LabVIEW/Can-I-detect-a-plot-name-change-event-in-a-plot-legend/td-p/2741164
https://forums.ni.com/t5/LabVIEW/XY-Plot-Scale-Legend-Mapping-Mode-Changed-Event/m-p/4226689
Let's Encrypt is an Certificate Authority (CA) that provides FREE TLS certificates for people and organisations to secure their websites and servers. Their certificates are valid for a maximum of 3 months, but client applications can automatically update the certificate when due.
It would be very nice to have this functionality in the NI web server. Exipiring certificates are cumbersome to manage.
The connector pane is a very useful feature for defining what the parameters for the VI are, therefore how it interacts with its environment.
On the other hand, the development experience did not age well. The 32x32 icon that is divided into smaller areas based on the pattern selected for the VI feel small on today's screens. On top of that most of the functionality is hidden behind the context menu.
This feels like a lacking experience for a crucial feature, but we grow accustomed to it, there we do not complain. But that doesn't mean things cannot be improved.
I would personally prefer a new window being opened when I want to edit the connector pane. The pane itself could be represented with 5x magnification (or even better, user selectable): 160x160 pixels.
On the pane, we could have a dedicated drop down that facilitates the selection of the pattern.
On each connector we could have a border representing its current state: Dynamic dispatch/Required/Recommended/Optional.
Cycling trough these states would be available on left click, for example, and reversing the direction with a shortcut, like ALT + left click.
Connecting the front panel terminals to the connector pane could be done by dragging and dropping to the desired place. To make sure that mistakes do not happen, the drag operations shall not move the front panel controls on the panel itself.
To make the workflow as smooth as possible buttons could be added to Apply the new connector pane, Apply and reorganize the front panel, Reorganize the front panel or Cancel the whole operation.
To make sure that we don't lose existing functionality the CTRL + left click shortcut shall keep the swap terminals functionality (a.k.a.: switcheroo).
Removing controls from the connector pane could be done by the right click, or left click for selecting the terminal and then using the Delete button on the keyboard.
Other operations inside the context menu, like the rotate by 90 degrees, add terminal, remove terminal, etc. could be made available via the menu of the window. I personally use these less, but if there is need for them, then we can discuss how they shall be presented on the window.
Since this idea was formulating over a long period of time in my head, but by no means lot of tought put into it, I'm very open to discuss the details. And, by no means the only or best solution to improve the Connector Pane UX.
"Despite the awesomeness of LabVIEW classes, the class constant icon size takes up too much space on the block diagram. Reducing the size of this box would be a helpful improvement.
I suggest minimizing the white space around the icon and reducing the depth of the box:
I couldn't find this explicitly mentioned here, but it seems related to:
Block diagram references should be 16 pixels tall (currently 19 pixels) - NI Community
Same Height of Unbundle by Name / Terminal / Local Variable - NI Community
Although making changes like this could hurt legacy code, earlier implementation is preferable. Local variables are already the same size as bundles and property nodes, but constants are not. My suggestion is to increase the size of bundle/unbundle elements by one pixel and decrease the size of constants by two pixels by reducing their border thickness. Since numerics require a type indicator, a 1 px border wouldn't compromise recognition. Numeric constant type visualization - NI Community
Instead of the two step process of wiring an input on the Connector Pane and then changing the terminal setting to Required through the right-click menu, holding down the Ctrl key while wiring the input will automatically set the terminal to Required.
I know there's a LabVIEW option to set all terminals to Required as default, but I usually use a mix of Required, Recommended and Optional.
Idea Part 1: The menu that appears when right-clicking an input of the Replace Array Subset node should contain Add Input and Remove Input options.
Idea Part 2: The QuickDrop Remove and Rewire tool (Ctrl + Space, Ctrl + Shift + R) should remove unwired inputs of the Replace Array Subset node.
This would be similar to the menus of several other well-loved nodes, such as the Build Array node.
Real-world example
The other day I wrote the following code:
Initially all the inputs of the Replace Array Subset node were wired. Then I realised I had made a mistake, and needed to remove the third-last pair of wires. I deleted the wires. So far so good.
I then selected the node and pressed Ctrl + Space, Ctrl + Shift + R to execute the QuickDrop Remove and Rewire tool, in the hope that it would eliminate the unwired input. It didn't. I then right-clicked the input, hoping to manually select Remove Input. That option didn't exist.
The only option I had was to manually disconnect the last four wires and reconnect them one input above, followed by removing the last input by dragging the bottom edge upwards.
Having to manually disconnect and reconnect wires was a little disconcerting. I wondered: what would have happened if I had made a mistake with say the second input, instead of the third-last input? A lot more manual wiring would have had to be redone.
Notes
The Wire Multiple Objects Together QuickDrop tool (Ctrl + W) is extremely useful. However, at the moment it has the following limitation.
The other day I found myself writing code like the following.
Naturally I tried using the QuickDrop Ctrl + W tool. However, it produced the result seen below, which is not what I wanted.
The Ctrl + W tool wires each source wire to a compatible (coerceable) destination. In the example above it wires to I32 and DBL destinations indiscriminately.
The desired outcome would be achieved if the tool preferred wiring to destinations that match the source data type exactly, before considering other compatible (coercible) destinations. In the example above, the tool should prefer the DBL destinations. It should wire to the DBL destinations first, before considering I32 destinations.
Notes
  • The example above shows 10 wires being wired between the Index Array node and the Replace Array Subset node. The real-world VIs I was programming the other day required wiring multiple pairs of Index Array and Replace Array Subset nodes, some with as many as 30 wires between them. Wiring them manually was a tedious and time-consuming operation.
  • This idea is somewhat related to the following idea: Improvement to the QuickDrop Ctrl+W tool: Wire constant to multiple destinations
The Wire Multiple Objects Together QuickDrop tool (Ctrl + W) is extremely useful. However, at the moment it cannot wire a block diagram constant to multiple destinations. It would be useful if it could.
Real-world example
The other day I found myself writing the following code.
I tried using Ctrl + W to wire the timestamp constant to each of the timestamp global variables. Currently the tool wires the constant to the first global variable only (leaving all other global variables unwired). Therefore I had to manually wire the constant to each of the other global variables, which is a tedious, manual operation.
Side-note: Global variables are used because they are computationally efficient (they can be read and written to very quickly). We needed code that ran in a tight loop (up to 1,200 times per second). The VI above performs the one-off initialisation of the global variables, before they start being read/written to in the loop.
It would be useful to have a Collapse All button in the Bookmark Manager.
It is tedious to click the "-" button for each bookmark group. Large projects can contain dozens of such bookmark groups. It currently takes too long (too much scrolling) to locate a given bookmark group.
Idea expansion: If a Collapse All button is added, it would perhaps make sense to add an Expand All button.
I am making ever more webservices with labview, but I feel I have little control over the server. It can happpen that a webservice becomes unreachable. Sometimes I would be a crashed webservice application, sometimes it is the NI webserver. But no tools available to find out. I can imagine the following tools in the NI webserver API
- start/stop server
- disable/enable server
- enumerate active webservices
- start/stop or enable/disbale webservices
- redirect domain root endpoint to webservice
- set favicon
- some proxy options would be nice to redirect a domain to a specific webservice
Hi all,
image processing is not anymore the "tough stuff"/"niche" of the past. Videos are everywhere now, maybe even more than sounds. So functions that handle video should be included in the cross-platform standard labview, at least for the essential functions (reading/writing files with a minimal set of codecs, acquisition of frames through ip or usb for common protocols, conversion between image format for display and processable data). This would attract a lot of young users. It would also jumpstart future developments of labview in the direction of AI.
Thx
VI Analyzer is great tool but can only perform static analysis on VI (as far as I know). It could be nice to run some tests on libraries / classes or even projects files as well to enforce good practices.
Problem: When an error occurs inside some DAQmx VIs, the error source (the string component of the error cluster) does not contain the call chain. This means that it is impossible to know the location where the error occurred based on looking at the error message.
Real-world example: The other day I encountered DAQmx error -200477 on a cRIO-9045 that uses DAQmx to acquire data from several different C-Series modules. The real-time application that was running on the cRIO contained an error handling module, which correctly logged the error to file. I saw the following when using PuTTY and the linux 'cat' command to display the contents of the error log file.
Notice that the error message does not contain any information as to where in the codebase this error actually occurred. This meant that I had to spend a few minutes inspecting the moderately large codebase before identifying the likely location of the error. Running subsequent tests I was able to confirm that that was the location of the error. The error was soon understood and fixed.
Root-cause: The root-cause of the issue (lack of call chain information) is the DAQmx Fill In Error Info.vi. In the real-world example above the error was occurring inside the DAQmx Timing (Sample Clock).vi.
The block diagram of this VI is seen below:
Any LabVIEW errors generated inside that VI are generated by the DAQmx Fill In Error Info.vi. This VI is, of course, essentially a simple translator between the return type (I32) output of the Call Library Function Node and a native LabVIEW error. That VI has an unwired input named depth whose default value is 1. This means that only the last link of the call chain is inserted into the error message.
Solution: Always insert the complete call chain inside all DAQmx error messages.
The default Data Directory path is set to "%Userprofile%\Documents" under windows.
This is fine regarding custom probes, settings etc, but problematic when it comes to the compile cache and other "runtime" files.
In our corporate setting, this folder is always synced with onedrive AND with the roaming profile. So one problem is, that it bloats the synced volume, which by it self is annoying. But it often leads to corrupt files when onedrive blocks them or writes them in the wrong moment.
So our workaround is to set this path to %programdata%\LabView Data. This, however, brings new problems, since now all users need write access to this folder.
I think a better way would be to save the folder under %localappdata%, but this can not be done with a symblic path and must be defined static, so it works just for one user.
Solution:
Provide a symbolic link to the %useroprofile% or %localappdata% folders. Additionally it would be nice, if the cache target folder could be seperately defined.
I have created NI MAX custom scales to use in a data acquisition system with a cRIO and LabVIEW.  As part of the Quality Management system at my company, I regularly calibrate instrumentation, and update these calibrations as custom scales in NI MAX.  My issue is that these calibrations/custom scales are a very important part of overall data integrity. The concern is multiple test users can gain access to NI MAX and randomly change the custom scales without knowledge of the Quality System manager, thereby compromising data integrity. Perhaps NI could look into allowing password protections of Custom Scales like they password protect the configuration of the cRIO system I am using.  This would help greatly to protect data integrity. Thanks for your consideration.
