Community Browser
Post an idea
Integrating markdown, asciidoc, whatever. This would help eliminate a step for most of us lowly third parties making docs for our software. A built-in browser would be nice, or just opening the doc straight away in a compatible viewer would be fine.
Loading the NI website's page for the help doc takes ages. This could also be a way to locally host vi docs and have a built-in browser-like display of help files.
I frequently find the context help information not detailed enough and get frustrated waiting for the website to load. If it was a one-stop shop markup-based doc, that's meaningful time saved.
(NOTE: This idea is the opposite of this one, so not the same)
The properties page of "boolean array to number" should prominently include the sign extension mode so we don't run into this confusion.
For string controls and indicators please add a vertical alignment option. We have applications where we will programmatically change the font size, which requires a string control/indicator to be sized for the largest option. Since there isn't a vertical alignment option, the string is always aligned to the top and it can make the front panel layout look strange.
Other applications have long strings that may be a single line or may be a variable number of multiple lines, but we'd like to be able to center the text vertically. Again, this requires the control/indicator to be sized for the largest option, but all the text is always vertically aligned to the top of the front panel object.
To "reduce friction" in creating subVIs from portions of code, I suggest adding "Create subVI from Selection" to the block diagram contextual menu- rather than only having it in the titlebar menu.
PPLs are a powerful tool in LabVIEW, and when working on larger plug-in based applications, they're almost essential.
As a developer, I do my best to not reinvent the wheel. This means building modular libraries for common functionality. Sometimes this includes base classes and interfaces, sometimes this includes functional globals. If I'm calling either of these from a PPL, it's necessary to first put this common code in a PPL too -- otherwise there will be class conflicts or conflicting instances of functional globals.
I would love to be able to distribute this common code as a VIPM package to vi.lib so that it's reusable across multiple projects -- however that's simply not possible now. While yes, you can technically put a PPL in vi.lib, you're guaranteed to be met with failure as soon as you build an application that relies on PPLs calling the vi.lib PPLs.
There are workarounds to all of this of course, but they all come with compromises, typically maintainability -- such as including a copy of all of your PPLs (and in my case, a library of public VIMs that sits next to each PPL) with every project, while not having access to the common functionality outside of any of these projects.
The solution could be as "simple" as this:
  • When PPLs are compiled, they currently expect each dependency to be at an exact relative path.
    • Why not support loading from one of a number of paths similar to, say, how .NET finds DLLs?
      • Search order could be something like: exact relative path, current folder, common LabVIEW folders, and custom (where custom could be defined in build specs)
    • When building a PPL/application that relies on PPLs, if you don't exclude dependencies, this would now allow all of those dependencies to actually find each other.
If we type up a list in a text label we can now (since LabVIEW 2023) right-click on it, select quick change and convert it to a number of different objects (array, enum, boolean etc)...Once you have done however, right-clicking on the result does not offer the quick change option anymore.
It would be nice and feel more consistent if the same option was available when right-clicking on the supported objects as well; allowing us to convert those to any of the other options and/or even back to the original list (which would allow you to then edit that list efficiently and then reconvert it). Basically an label/object to object/label quick change, instead of just label to object.
PS. I know there are various quick drop plugins that do parts of this, but this would extend the now in-built function to cover those and more scenarios...
Many times data is generated or transformed using a function or vi with a single output. In those cases the wire name is the one given by the function or VI terminal, but it would far more descriptive if the wire could have a proper name according to is usage in the block diagram. You can attach labels to wires but these are not propagated particularly when used in places like "bundle" or in structures (for, while, etc.). In large diagrams thus it can be difficult sometimes to now what a wire is for.
This idea proposes to enable the override of the default name of the wire connected to output terminal to that of the label of the function, in case the label is not empty, for single output function or VI. In a similar fashion to the propagation of labels of constants. This could be automatic (not empty label) or deliberate (for instance, using a tick box in the properties page)
This is different from idea Allow-Wire-Labels-to-Dictate-Name-Inheritance-in-Bundles in that it follows the current LabView behavior of the wire name being dependent on labels on constants, and avoids possible conflicts.
It would be good if, after adding a custom image to the states (TRUE, FALSE, transitions etc.) or text of of a Boolean control using the Control Editor if there was an option to revert to the standard image rather than having to replace it by overwriting with a second image.
It'd be quite helpful if you could have several search result windows (or tabs) since it's not that uncommon that you e.g. search for some text and want to keep that list of VIs while searching for something else. Especially when the projects get into several thousand VIs it takes a while to do the search, thus i prefer to not do it again ...
If we want a ring of a string type we can use a combo box and if undefined items are not to be allowed it *could* behave as a regular ring (integer type) with no text editing/input, but that is not an option in LabVIEW now. Having such an option would allow us the keep the behaviour of multiple ring controls identical (and hence more intuitive to the users) although their types behind the scene for programmatic convenience are different.
If you want to keep the ring as a string (to not have to deal with it indirectly though the ring/enum string array property, which would be the current workaround...) you are currently forced to accept that the this ring will behave differently than other ring controls or enums:
In Microsoft applications the suggested feature is available by setting the style of the combo box to DropDropDownList.
A very common task when operating with 2D pictures are mouse down/move events where we are interested which pixel was just clicked. While there is an event data node for the clicked coordinates these are relative to the front panel and translating them into image pixel coordinates is a chore and requires jumping through flaming hoops tweaks. (i.e. label yes/no? zoom factor? etc.)
However, there is a "Mouse" property for 2D images that has all the information directly in pixel coordinates and mouse button states. Currently, we need to read that property inside the mouse event to easily get the information we always (always!!!) want in such an event!
It would be cleaner if mouse events on pictures would output these mouse properties directly as an additional event data node.
Two clear advantages:
  • Cleaner code for those who know how to work with this property.
  • Stop sending newbies on a snipe hunt trying to figure out how to translate the current "coords" event data node into something useful for the intended task.
Here is an example where this idea would have helped
Here's a picture for the graphical thinkers!
Thanks for voting!
If you e.g. open a project in a newer LV and then close it; it starts recompiling everything with no abort option, and only after having recompiled 2000 VI's i can choose to _not_ save them ...
I just opened it to check a few things and ended up with Kill Process to get out of it.
Let us cancel/abort the recompile when shutting down.
I often find my self right-clicking the VI, either in the block diagram where it's used or on the icon at the top-right, but each time I'm reminded that this function does not exist (yet!). It would be really useful when navigating in large projects if you could right-click the VI and find it in the project. Often I want to get to its class to find other VIs that I'm looking for and sometimes to check where the class is used by the rest of the code.
In LabVIEW, we can create a polymorphic VI, but polymorphic VIs are made by creating multiple disparate VIs and logically tying them together. What I'm proposing is a single VI which can be used to perform many different functions, as is normal in many text languages.
Imagine a class with 10 different functions, and the ability to read/write from each. We'd have 20 similar VIs. I propose a single VI with a tabbed front panel. When you select a different tab, you'd see a different block diagram. Each could have a different connector pane. When saved, it would create a single file. On a palette, it would be a single function. We could use a polymorphic selector to choose which function to operate on.
This would simplify distribution of classes and drivers.
When I add block diagram comments inside a structure, they are often long enough to require several lines.  Since auto-grow is on, I need to stop typing before the comment reaches the edge of the structure, resize the comment to be multi-line, select inside the comment again, and re-start typing.  From then on, the comment word wraps at  my sized width.  Could you make a special character like ctrl-, alt-, or Shift-comment move me to the next line and make the comment that wide, so it word wraps at that width from then on?  While you're at it, could a word-wrapping comment autogrow in height to fit the comment, like a one-line comment auto-grows in width?  Subdiagram comments could use that feature, too.
I understand that empty interface boxes should reflect their purpose, but this design decision wastes too much block diagram space. When using interfaces, explicit type casting is often necessary by definition. Unfortunately, this quickly clutters the block diagram.
When adding a file via the project tree to a .lvlib or .lvclass, it is highly likely that the file is located in the same folder as the corresponding .lvclass. For .lvlib, the file is either in the same folder or one level deeper.
When using the right-click menu Add File... on a .lvclass or .lvlib, the Select File to Open dialog should automatically navigate to the folder containing the .lvclass or .lvlib.
Currently, it navigates to the previously used folder instead.
This should immediately navigate to the folder containing Cell.lvclass.
In many programs you can open/close all children (neighbours?) of a Tree node by holding control. It'd be nice it that worked in LV as well. (atleast it doesn't in 2019)
I mean 1 level down, not _all_ if there's several.
Ctrl+click the '+' and it should open all the neighbour classes, if it's open all should be closed.
For projects, libraries, and their associated files, if the "Save Version" property is set to an earlier version of LabVIEW, the project and its files are not recompiled to the editor version.  There should be an option on the Mass Compile dialog that allows the "Save Version" property of projects, libraries, and classes to be overridden.
Currently, on Windows, File:Save As:Rename does not work when changing only the capitalization of a filename. I would prefer that it did. See this discussion for workarounds.
saving with lowercase:
Has no affect on the filename in the finder or in LV.
