4 | |
4 | |
3 | |
3 | |
3 |
I printed my block diagram and the "case" structures displayed the option with a single wire going through.
I think you should look for which option under the case has the highest number of operations, and switch the case to that, then print it.
You could put that as an option in the "print" interface.
