6 | |
6 | |
3 | |
2 | |
2 |
a transaction log of all docked probe window activity, in a human readable format if possible. it should include probe position declaration, timestamp, data and conditional probe result. the transaction log is 'dumped' in a separate window, and optionally saved to disk. it is meant to work a bit like dbgview, which displays information sent via OS outputdebugstring() or debugprintf() on windows. maybe something like this already is implemented in the desktop execution trace toolkit 'DETT', but this idea is only for data of probes and is native to IDE. if gives a migrate path to DETT to see more info about execution behaviour...
