6 | |
6 | |
3 | |
2 | |
2 |
The One Button Dialog presents a dialog to the user and suspends all User Interface operations, including any Events. In most cases this is OK, however at times it is desirable to presents a message to the user and continue execution. I have just had this need (again) and did the usual process of creating a subVI, setting it's properties appropriately and calling in a parallel loop through a queue. Even after this effort (it took several attempts to get it right), the dialog doesn't look the same, so is lacking.
The proposal presented here is to have a "floating" One Button Dialog (in addition to the existing one). The dialog would be displayed and execution can continue. That is, the user is notified that something has happened, but execution can continue.
