LabVIEW Interface for Arduino Discussions
Adafruit Motor Shield Driver Problems
My computer shows the following path to the firmware that is compiled by the Arduino Integrated Development Environment and uploaded to an Arduino board.  The two main source files for the firmware are LIFA_Base.ino  and LabviewInterface.ino.
"C:\Program Files\National Instruments\LabVIEW 2012\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base"
When you installed the firmware did you open the LIFA_Base.ino file, compiled it and upload the compiled file to your Arduino board?  You should be using 2.2.0.79 version of the firmware.
Please provide the complete path on your computer to the LVIFA file you said did compile and to the LIFA file you said did not compile.   We need this information so we can determine why LVIFA will compile and the LIFA will not compile.
For the record if one wanted to modify the LFA code to work with the version 2 Arduino Motor Shield one would be modifying the LIFA_Base.no and LabviewInterface.ino files.  However, because of the time it would require I will not provide detailed instructions to show you what needs to be modified.  Instead the modifications could be done by an experience programmer who can examine the source files to determine what needs to be done.
As tame permits I will work on a sketch for use with Labview that does not use LIFA.  However, if you are impatient you could buy the original version of the Arafruit Motor Shield.  Here is a source for the original version.
<http://www.amazon.com/SainSmart-L293D-Shield-Arduino-Duemilanove/dp/B00813HBBO/ref=sr_1_2?ie=UTF8&qi...>
hrh1818
Message 11 of 39
(2,948 Views)
This is the location of the .pde file, this is the file that complied
C:\National Instruments Downloads\National Instruments Downloads\LVIFA_Base_2.1.1.69\LVIFA_Base
the LIFA location is .ino file that did not complie is
C:\Program Files (x86)\National Instruments\LabVIEW 2013\vi.lib\LabVIEW Interface for Arduino\LIFA_B...
i will attach a copy of the error it gives.
I really appreciate your assistance with this and im a patient person so there is no rush i would rather try to get this card working than buy another.  also i came across this disscussion let me know if you think this might be a good approach.
https://decibel.ni.com/content/thread/18700
Message 12 of 39
(2,948 Views)
Message 13 of 39
(2,948 Views)
Your Arduino IDE is not properly opening all required files.  It is missing LabVIEWInterface.ino.  This is why it won't compile.  Also, make sure you are not using the beta version of the Arduino IDE.  Use version 1.0.5.
Message 14 of 39
(2,948 Views)
ok well at least were figuring out what is wrong.  how do i go about fixing this?  andim using arduino 1.0.5-r2 not sure if thats beta
Message 15 of 39
(2,948 Views)
Message 16 of 39
(2,948 Views)
or should i just try that Linx thing you guys were talking about?
Message 17 of 39
(2,948 Views)
LINX is a nice product.  But it won't fix your version 2 Adafruit Motor Shield problem.  LINX does not have built in support for motor shields.  As of today LINX does not have support for DC motors or Stepper motors.
In the forum there is a request for stepper motor support and in the thread somebody ask for support for the version 2 Adafruit Motor shield.   Sammy says it is on his to do list but did not provide a time estimate of when motor shield support will be available.
hrh1818
Message 18 of 39
(2,948 Views)
I suggest you use the VI Package Manager to check the installation of the LIFA firmware on your computer.
Run the VI Package Manger. Then scroll down until you see the "Labview Interface for Arduino" line.  It should show version 2.2.0.79.  If not use Menu > Package > Upgrade all Installed Packages to install version 2.2.0.79.
You aid this was the path to the LIFA version that did not compile.
This path looks very suspicious.  There should be a Firmware folder  after "Labview Interface for Arduino" and before LIFA_Base in the path.
Try this path to see if the LIFA firmware complies.
C:\Program Files (x86)\National Instruments\LabVIEW 2013\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base
hrh1818
Message 19 of 39
(2,948 Views)
ok i uninstalled the labview interface and reinstalled it to ensure i have the latest one and i will post the errors in complining.  And in response to earlier, yes you are were right it was in the ...LabVIEW Interface for Arduino/firmware/LIFA_Base and still get errors.  theres a ton of errors this time.  maybe i should uninstall some of these things and reinstall because it seems there are files that are not in their correct locations.  What should i uninstall?  the Arduino exe?
Message 20 of 39
(2,948 Views)
