LabVIEW Interface for Arduino Discussions
MPU6050+Arduino+Labview
According to the documentation, the FIFO supports burst reading (which I'm assuming means that the register pointer is not incremented like it is for reading multiple registers like the standard data registers 59 through 72).
So, you should be able to just specify register 0x74 and request how ever many bytes are available in the FIFO buffer as specified by the FIFO_COUNT registers.
I'm curious to see your LabVIEW code where you are reading the interrupt pin because it can't be reliably detected via LIFA (since you can only poll the pin which is relatively slow through LIFA).
Message 31 of 35
(3,803 Views)
hi friend can you tell me, how do you connect the mpu in the myrio ?
appears an error when i compile it about the i2c
Message 32 of 35
(3,803 Views)
For support for the myRIO, it is recommend that you post in the official
myRIO (Academic Hardware Products) forum. If you are using LINX, you should
post on the LINX forum.
Message 33 of 35
(3,803 Views)
can i get ciruit diagram
Message 34 of 35
(3,616 Views)
hello
am searching for trarting with gyroscope i dont understand how i do this please tel the way to do that correctly
and thanks for your help !!
Message 35 of 35
(2,741 Views)
