LabVIEW Web UI Builder and Data Dashboard
Function wait(ms) in labview web UI builder
Does the function wait(ms) in LabVIEW web ui builder include processing time?
(9,188 Views)
Accepted by LawrenceChong
Hi Lawrence,
I think your question is asking whether the wait (ms) will block the cpu. In labview and webUI the function will not block the rest of the code from executing. You might want to make a structure such as shown below to see this:
You will see that if "Wait time" is greater than "Execution Time" the loop speed will be limited by the "Wait Time" and vice versa.
Does this answer your question
Jesse Dennis
Engineer
INTP
(9,165 Views)
