0x%08lx error
Oh, and another thought... Is the improved error logging capability accessible from the installers that the 8.x applications builders create? That would be really useful...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 24
(3,472 Views)
Mike, sorry about that.  I didn't mean to address the wrong person.
The answer to your question is not easy.  The error is a simple access violation, which means that the program tried to access memory outside the bounds set by the OS.  Each time this error is seen, it seems to come from a different source.  It is a very machine specific error, which makes replication extremely difficult.
For your other question, yes you can create a log file, just like with the LabVIEW installation with installers you create with the Application Builder.
I hope this helps.
Brian Coalson
Software Engineer
Message 12 of 24
(3,467 Views)
I am sorry I did not make clear that my labview is 7.1
regards
Message 13 of 24
(3,463 Views)
Rajendra, Mike 21052,
Updating your installer framework with the files that I attached previously should be the solution to this error.  Mike21052, are you seeing a different error now?
Brian Coalson
Software Engineer
Message 14 of 24
(3,449 Views)
Yes,
this is the error message I am getting now.
.\ConfigInfo.cpp(2794): IInstallerError 11006
Developer Error. The following errors were found in your ini file:
1. Missing Key: [UserInfoDialog] RegSNProp
Correct the ini file and try again.
<No Debug Message>
Message 15 of 24
(3,445 Views)
Mike,
Is the following key in your ini file under "Settings"?
RegSNProp=LVREGSERIALNO
Also, are you using the base, full, or professional distribution?
Brian Coalson
Software Engineer
Message 16 of 24
(3,425 Views)
Yes it is.
I have the Professional Distribution.
Message 17 of 24
(3,398 Views)
I realize that this thread is old but I will add this note anyhow hoping that someone might find it when having this problem. This particular error can be an infinite loop and "removing and reinstalling all NI software" solution will not help an only adds to the frustration. The problem is in that various remnents are left behind from other installers, whether it is NIs installers alone or others I do not know. In any case the quickest way to get back up and running is to rename a temp. I am running w2k on my target machine so your solution may be slightly different. Rename the "C:\Documents and Settings\Administrator\Local Settings\temp" temporarily so that the installers can continue afterwards you can put it back to the original name if you choose ... it is a temp directory so would hope that it would not matter since I new one will be created when needed. Keith
Message 18 of 24
(3,162 Views)
I am getting the following error while trying to install LabView Full Development system 7.1 from my hard driver:
"Developer Error: The following errors were found in your ini file: 1. Missing Key: [UserInfoDialog]RegSNProp"
I noticed that Mike had asked this last year, but doesn't look like any resolution from it. I tried renaming the Temp directory, but did not help.
HP
Message 19 of 24
(3,038 Views)
Hi HP,
Please try this KB, this should help.
Do you have the following line in your ini file?
If you insert the following entry at the end of the setup.ini file, the installer will launch without an erro
If not, please contact National Instruments for further support
Good luck
Van L
NI Applications Engineer
Message 20 of 24
(3,018 Views)
