0x%08lx error
Hi
I have exactly the same problem but I am using Measurment Studio 7.0.
I tried the updated files before, but the installer reject to install because the version is too old.
So could you suggest a solution for this case?
Message 21 of 24
(1,337 Views)
Hey Mamingcao,
Have you tried transferring all the installer files to the hard disk?
What errors do you get? Do post up a screen shot?
Aashish M
CEO
TransferFi
www.transferfi.com
Message 22 of 24
(1,297 Views)
Sorry I cannot post Screen Shot because my company have very strict limit about internet......
the error is exactly same as first post:
"The instruction at "0x%08lx" referenced memory at "0x%08lx".
    The memory could not be "%s"".
It appear just after I double clicked "setup" . I already copy to hard disk. But still same.
I tried patch provided before. But seems it is for 8.2 ~ my version is too old. Installer reject to continue.
Seems is my computer have some problem~ I am preparing to reinstall XP.
Message 23 of 24
(1,291 Views)
I have the same problem with Labview 7.1
I copied the files in the local driv
tructured Exception number 0xC0000005
Exception code: C0000005 (ACCESS_VIOLATION)
Fault address:  75000B E1FD90:0000000E
Registers:
EAX:001BF19D
EBX:00E1F9BC
ECX:0045007B
EDX:7C9032E3
ESI:00000001
EDI:00536F80
CS:EIP:001B0075000B
SS:ESP:002300E1E9F0 EBP:00E1F9C8
DS:0023 ES:0023 FS:003B GS:0000
Flags:00010216
Stack Trace
Address  Frame    LogicalAddr    Module    SymbolName + Offset
0075000B 00E1F9C8 0000:00000000
0042271D 00E1FBCC 0001:0002171D C:\Labview 7.1_Commercial Engineering\Installation - Disk 1\setup.exe
00421AFF 00E1FCC4 0001:00020AFF C:\Labview 7.1_Commercial Engineering\Installation - Disk 1\setup.exe
00469FEC 00E1FD78 0001:00068FEC C:\Labview 7.1_Commercial Engineering\Installation - Disk 1\setup.exe
0046A0E6 00E1FD9C 0001:000690E6 C:\Labview 7.1_Commercial Engineering\Installation - Disk 1\setup.exe
00472121 00E1FDE4 0001:00071121 C:\Labview 7.1_Commercial Engineering\Installation - Disk 1\setup.exe
004721DE 00E1FF18 0001:000711DE C:\Labview 7.1_Commercial Engineering\Installation - Disk 1\setup.exe
004F7119 00E1FF80 0001:000F6119 C:\Labview 7.1_Commercial Engineering\Installation - Disk 1\setup.exe
004D69AE 00E1FFB4 0001:000D59AE C:\Labview 7.1_Commercial Engineering\Installation - Disk 1\setup.exe
7C80B729 00E1FFEC 0001:0000A729 C:\WINDOWS\system32\kernel32.dll GetModuleFileNameA + 442
Message 24 of 24
(903 Views)
