1D array to a 2D array
I have constants of an Array.. I want to insert the an element to each of those contants, like FAILED OR PASSED. Can someone show me how to create 2D array? thanks
Krispiekream
Message 1 of 8
(6,014 Views)
You don't need a 2-D array.  Use a cluster to hold both the number, and string values, and then create an array of that cluster.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
Message 2 of 8
(6,009 Views)
In fact, you CAN'T have a 2D array like you want, because all the items in an array have to be of the same data type. So, you can have a 2-item cluster of 1-D arrays (separate number and P/F arrays) or a 1-D array of 2-item clusters (number-P/F clusters), whichever way your application would work with easier (the packing order will determine which characteristics are easier to get to).
Unless, you wanted to code Pass = 1, Fail = 0, then you could have a 2-D array.
Then, there's always a database Smiley Wink .
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 3 of 8
(5,993 Views)
i have changed my numbers to string so it is seen as text.
Krispiekream
Message 4 of 8
(5,986 Views)
It would make more logical sense to use a cluster, unless you are displaying this in a table.
If you create an array of your Pass/Fail results, then you need to use Build Array (make sure concatinating is turned off).  You may have to use Transpose 2D Array to get it to display the way you want.
Message 5 of 8
(5,983 Views)
i am actually trying to print out the table of pass/failed devices.
i am just having a problem inserting the FAIL/PASS into the current CONSTANTS ARRAY OF DEVICES.
Krispiekream
Message 6 of 8
(5,980 Views)
Accepted by krispiekream
Something like this?
Message 7 of 8
(5,969 Views)
yes!!1
thanks you!
thats exactly all i needed.
Krispiekream
Message 8 of 8
(5,964 Views)
