2 Microphones. Buffer overflow.
I'm getting a buffer overflow error while acquiring data from 2 microphones.
I'm sampling  at 22050 S/s with 5000 S/ch.
Within a second I get the error,
"Error 4823 occurred at Sound Input Read (DBL).vi->New.vi
 Possible reason(s):
LabVIEW:  (Hex 0x12D7) You cannot perform this operation without an active task.  Ensure that a task is active and try again. An input task might stop running if the input buffer overflows. Overflow occurs when the data is not read fast enough."
Is there something I can do to fix this? I tried playing with the S/ch and S/s values but couldn't fix the problem.  I would think this will become a bigger problem when I try more than 2 microphones. I searched online for a solution to this problem but couldn't find anything that worked for me.
Thanks very much. Examples or any suggestions are greatly appreciated.
Message Edited by ap8888 on 03-16-2010 12:02 AM
(3,866 Views)
Accepted by ap8888
(3,862 Views)
