24 hour timer query
Hi!
I am trying to set up a case where the user has the ability to set the input of a timer for my 3 LED lights RED, GREEN, BLUE.
The sort of input i am looking for is to prompt the user to set the period of lighting
For example
16:8 which is 16 hours of light 8 hours of darkness. I would hope this could run in a loop until either a stop button is pressed or the amount of cycles in days is set.
Can someone please offer some advice. I have tried different methods but cant seem to get a handle on how to approach the task
Message 1 of 15
(6,747 Views)
Not able to View your code (using Lower LV version)
Using Get Date and time in seconds function,  subtract initial time from current time which will give you the time difference, continue the same till you reach target time (assume 16 hours of light), once you achieve 16 hours again re initiate the start time and subtract with current time for darkness
Message 2 of 15
(6,739 Views)
Sample solution. This may give you an hint.
Message 3 of 15
(6,729 Views)
Hello PalanivelIT, thank you for the hint solution. i will implement it now and see how it goes. and perhaps post some photos if i require
Message 4 of 15
(6,719 Views)
Not sure if that solves the issue, there is alot more going on in the interface that you might not be able to see 😞
Message 5 of 15
(6,696 Views)
How about something like this?
=== Engineer Ambiguously ===
Message 6 of 15
(6,693 Views)
Gday RTSLVU
its only the lights on the red/green/blue arrangements. Attatched is the files associated with this problem
thanks in advance 🙂
Message 7 of 15
(6,680 Views)
I can't see your code as I am only running LabVIEW 2017 here.
Message 8 of 15
(6,679 Views)
You are not attaching all of the files needed for your VI.
You should/need to use a State Machine, my favorite is JKI.
The JKI State Machine has an event structure in it, you can set a nominal timeout case to check the time elapsed and cycle your LEDs accordingly. You can do this while allowing the user to control the front panel and change things, ie, turn motor on, etc.
mcduff
Message 9 of 15
(6,666 Views)
I too cannot run the code since there are multiple subVI's missing. Please include all code so people on the forum can assist you.
Message 10 of 15
(6,646 Views)
