finding array from an array
so i am trying to find a missing numbers in a 1D array but can't seem to find a way to pass through the if else if anyone can help me with it
Message 1 of 13
(6,448 Views)
Is your question is finding element from an array or array from array?
If Finding Missing Element is your requirement use Search 1D array .
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 13
(6,446 Views)
I hope this is your solution.
Message 3 of 13
(6,428 Views)
Trying to find a way to find all the missing values in an array but can't seem to find it can anyone help me with that
Message 4 of 13
(6,381 Views)
this help but i am trying a general solution in which value is given by the use and it could be of ant value and find all the missing values
foe example:
array 1D: 2 4 6 7
Ans: 1 3 5
this should be the answer
Message 5 of 13
(6,418 Views)
trying to find the missing element in an array
Message 6 of 13
(6,415 Views)
Seems like academic work, still you can refer this!
Message 7 of 13
(6,410 Views)
Duplicate Post
https://forums.ni.com/t5/LabVIEW/finding-array-from-an-array/td-p/3841458
Message 8 of 13
(6,378 Views)
 palanivel when i try to connect this with the 1D search array it shoes a bad connection
Message 9 of 13
(6,402 Views)
Already array input node is there   why you need to connect to1D array
Share the code snippet of yours
Message 10 of 13
(6,382 Views)
