finding array from an array
just uploaded the vi if you can check
Message 11 of 13
(1,120 Views)
Accepted by hasnain123
You need to go through basic LabVIEW Tutorial
For your Problem Refer this Link https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAghSAG
Message 12 of 13
(1,111 Views)
thanks for the help btw i have to go through a lot of thingd just started working on labview after 2 years
Message 13 of 13
(1,089 Views)
