finding array from an array
just uploaded the vi if you can check
Message 11 of 13
(1,150 Views)
Accepted by topic author hasnain123
You need to go through basic LabVIEW Tutorial
For your Problem Refer this Link https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAghSAG
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 12 of 13
(1,141 Views)
thanks for the help btw i have to go through a lot of thingd just started working on labview after 2 years
Message 13 of 13
(1,119 Views)
