2D array labview to C/C++/JS.. form array!!?
How i can to convert the 2D array in labview to 2Da rray string like in the C/C++/JS like this but in a dynamic way!
Thank you for your help!
(5,549 Views)
That's a simple formatting question, right? Do you want a 3x3 solution or an universal solution?
I would autoindex on an FOR loop, use "array to spreadsheet string" with comma as delimiter on each row (1D array), pad with brackets, autoindex the outputs and repeat on the 1D string array after the FOR loop once more. See how far you get.
(5,543 Views)
Thank you for your response but i searsh an universal solution(dynamic), I wanted to know if there was already someone who made this application.
(5,536 Views)
My solution IS an universal solution that works on any size array. Have you tried?
(Please explain your use of the word "dynamic". It's ambiguous here)
(5,534 Views)
not yet I'll try it and I'll keep you informed thank youuu
(5,531 Views)
Accepted by EMCfrance
Here's how it could look like. Works for any size, even non-square arrays. Change the format for other numeric types (DBL, etc.)
(5,527 Views)
it work thank youuuuu very much.
(5,492 Views)
