32bit float value from analyzer
@sandy1234 wrote:
Attached the code which I tried by creating just two 16bit registers ie 40005 and 40006 and it was working (My laptop LV2014 is having some problem while deploying so tried in another PC).
The missing subVI is probably more relevant to see. It seems to take two I32, (but obviously coerced to something else?) to create a SGL. Attach the subVI instead!
Message 21 of 24
(1,262 Views)
Base on the name and connector pane think it's the subVI in post #5.
GCentral
Message 22 of 24
(1,255 Views)
Please find the attached VI and subvi its just joining and swapping the two variables with 16bit registers..
Guys I was not well for a week so this is not yet tried..I will update for sure and thanks for posting the suggestions
Regards
Sandy
Message 23 of 24
(1,230 Views)
I have created a UINT16 with address 400001-400050 and used the typecast function followed by SGL array but could not find the array of values from the device...am I doing something wrong?
Sandy
Message 24 of 24
(1,201 Views)
