3D bar graph with time stamp on X-axis
Hi all....I try to plot date data (first column in array)  to x axis in 3D bar graph follow by example in this link
http://forums.ni.com/t5/LabVIEW/3D-bar-graph-issues-using-2D-Y-Z-plane-and-timestamp/td-p/1923027
But I still do not succeed. Cat Sad Cat Sad Cat Sad
 I'll be glad if you had any suggestions that could help.
Thank you
HiN
(3,435 Views)
Hi Jubchay,
Here is an example of displaying the given timestamp. Only the 3D vision has the customized marker.
The 3D Bar is not suitable to display a lot of bars, which make the marker overlapped. So I only input the subset of 15.
(3,426 Views)
Thank you for this solution Heart
If can't use 3D bar graph for display 2D bar graph
Can I use XY Graph to plot multi bar graph?
Do you have solution for XY graph?
Thank you very much Cat Embarassed
(3,423 Views)
I don't have a solution at hand. But I know that you can use the legend to display the line graph as a bar graph.
(3,412 Views)
Thank you but If i change line graph as a bar graph.
Single plot is OK but Multi plot is not OK because graph will be overlap
Thank you for answer if will try another way. 🙂
(3,409 Views)
